Ir para o conteúdo principal
Philips TAS7505 Speaker Replacement
O que você precisa
  1. Philips TAS7505 Speaker Replacement, Speaker: passo 1, imagem 1 %32 Philips TAS7505 Speaker Replacement, Speaker: passo 1, imagem 2 %32 Philips TAS7505 Speaker Replacement, Speaker: passo 1, imagem 3 %32
    • Using the opening tool, remove the rubber padding from the bottom of the speaker.
    • The rubber padding is glued on and may require reapplying adhesive to re-assemble.
  2. Philips TAS7505 Speaker Replacement: passo 2, imagem 1 %32 Philips TAS7505 Speaker Replacement: passo 2, imagem 2 %32 Philips TAS7505 Speaker Replacement: passo 2, imagem 3 %32
    • Using the Philips screwdriver head #0, remove all four screws holding the plastic plate in place.
    • Use the same opening tool from the previous step to remove the plastic plate.
  3. Philips TAS7505 Speaker Replacement: passo 3, imagem 1 %32 Philips TAS7505 Speaker Replacement: passo 3, imagem 2 %32 Philips TAS7505 Speaker Replacement: passo 3, imagem 3 %32
    • Now that you have removed this cover, there is another cover. This cover has a total of 9 screws that can be removed with the Philips 0-bit screwdriver bit.
    • Once all these screws are removed, you can take off the cover
  4. Philips TAS7505 Speaker Replacement: passo 4, imagem 1 %32 Philips TAS7505 Speaker Replacement: passo 4, imagem 2 %32 Philips TAS7505 Speaker Replacement: passo 4, imagem 3 %32
    • Squeeze the white connector on the bottom to release a clip that is hidden from sight. This will allow it to be wiggled free.
    • Remove the battery from the speaker by disconnecting the white connector from the motherboard.
  5. Philips TAS7505 Speaker Replacement: passo 5, imagem 1 %32 Philips TAS7505 Speaker Replacement: passo 5, imagem 2 %32 Philips TAS7505 Speaker Replacement: passo 5, imagem 3 %32
    • Find the rubber flap that covers the USB-A and USB-C port
    • Pull on the rubber flap, it should come out whole as shown in the second image
    • Once taken out the rubber flap, pull the interior of the speaker
  6. Philips TAS7505 Speaker Replacement: passo 6, imagem 1 %32 Philips TAS7505 Speaker Replacement: passo 6, imagem 2 %32
    • Once you have the speaker body out, unscrew the four screws holding the speaker down
    • Use Philips screwdriver head #0
  7. Philips TAS7505 Speaker Replacement: passo 7, imagem 1 %32
    • Pull the motherboard out then disconnect the white connector of the speaker by wiggling it back and forth.
    • See the motherboard repair guide for more in-depth instructions on this part
  8. Philips TAS7505 Speaker Replacement: passo 8, imagem 1 %32 Philips TAS7505 Speaker Replacement: passo 8, imagem 2 %32 Philips TAS7505 Speaker Replacement: passo 8, imagem 3 %32
    • The speaker will look like this if you have followed the steps correctly
Conclusão
Frederick Jimenez
Membro desde: 09/26/22
277 Reputação
Autoria de 2 guias
Equipe
CSU Los Angeles, Team 5-2, Adachi Fall 2022 Membro de CSU Los Angeles, Team 5-2, Adachi Fall 2022
CSULA-ADACHI-F22S5G2
Membros da 5
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 28
Duração total: 603
