Ir para o conteúdo principal
Philips Sonicare ProtectiveClean 6500 Motor Replacement
O que você precisa
  1. Philips Sonicare ProtectiveClean 6500 Motor Replacement, Internal Assembly: passo 1, imagem 1 %32 Philips Sonicare ProtectiveClean 6500 Motor Replacement, Internal Assembly: passo 1, imagem 2 %32 Philips Sonicare ProtectiveClean 6500 Motor Replacement, Internal Assembly: passo 1, imagem 3 %32
    • Pry the bottom cap away from the toothbrush body.
    • Pry the bottom cap away from the toothbrush body until it releases.
    • Remove the bottom cap by hand.
  2. Philips Sonicare ProtectiveClean 6500 Motor Replacement: passo 2, imagem 1 %32 Philips Sonicare ProtectiveClean 6500 Motor Replacement: passo 2, imagem 2 %32
    • Use a metal spudger to release the two retaining clips inside the device.
    • The clips release when pried inward.
  3. Philips Sonicare ProtectiveClean 6500 Motor Replacement: passo 3, imagem 1 %32 Philips Sonicare ProtectiveClean 6500 Motor Replacement: passo 3, imagem 2 %32
    • Slide the internal assembly out of the chassis.
  4. Philips Sonicare ProtectiveClean 6500 Motor Replacement, Motor: passo 4, imagem 1 %32 Philips Sonicare ProtectiveClean 6500 Motor Replacement, Motor: passo 4, imagem 2 %32
    • Use an opening tool to gently pry the ribbon cable away from metal motor chassis.
  5. Philips Sonicare ProtectiveClean 6500 Motor Replacement: passo 5, imagem 1 %32 Philips Sonicare ProtectiveClean 6500 Motor Replacement: passo 5, imagem 2 %32
    • Locate the twisted copper wires feeding from the top of the motor to the upper corner of motherboard.
    • Desolder the contact points.
    • Soldering can cause burns and fires. Always solder in a well-ventilated workspace.
  6. Philips Sonicare ProtectiveClean 6500 Motor Replacement: passo 6, imagem 1 %32 Philips Sonicare ProtectiveClean 6500 Motor Replacement: passo 6, imagem 2 %32
    • Desolder the two connections.
  7. Philips Sonicare ProtectiveClean 6500 Motor Replacement: passo 7, imagem 1 %32 Philips Sonicare ProtectiveClean 6500 Motor Replacement: passo 7, imagem 2 %32
    • Turn the assembly over and remove the Phillips screw.
  8. Philips Sonicare ProtectiveClean 6500 Motor Replacement: passo 8, imagem 1 %32 Philips Sonicare ProtectiveClean 6500 Motor Replacement: passo 8, imagem 2 %32 Philips Sonicare ProtectiveClean 6500 Motor Replacement: passo 8, imagem 3 %32
    • Pull the motherboard and motor gently away from the motor chassis.
  9. Philips Sonicare ProtectiveClean 6500 Motor Replacement: passo 9, imagem 1 %32 Philips Sonicare ProtectiveClean 6500 Motor Replacement: passo 9, imagem 2 %32
    • Use a pointed tool to push in the tabs on either side of the white assembly .
    • Pull the wire carrier off of motor chassis.
    • Swap it to the new motor chassis.
Conclusão
Liam Casto
Membro desde: 04/01/24
354 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team 1-4, Harley Spring 2024 Membro de IUPUI, Team 1-4, Harley Spring 2024
IUPUI-HARLEY-S24S1G4
3 Membros
Autoria de 3 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 21
Ao todo: 172
