Ir para o conteúdo principal
Philips Sonicare ProtectiveClean 6500 Battery Replacement
O que você precisa
  1. Philips Sonicare ProtectiveClean 6500 Battery Replacement, Internal Assembly: passo 1, imagem 1 %32 Philips Sonicare ProtectiveClean 6500 Battery Replacement, Internal Assembly: passo 1, imagem 2 %32 Philips Sonicare ProtectiveClean 6500 Battery Replacement, Internal Assembly: passo 1, imagem 3 %32
    • Pry the bottom cap away from the toothbrush body.
    • Pry the bottom cap away from the toothbrush body until it releases.
    • Remove the bottom cap by hand.
  2. Philips Sonicare ProtectiveClean 6500 Battery Replacement: passo 2, imagem 1 %32 Philips Sonicare ProtectiveClean 6500 Battery Replacement: passo 2, imagem 2 %32
    • Use a metal spudger to release the two retaining clips inside the device.
    • The clips release when pried inward.
  3. Philips Sonicare ProtectiveClean 6500 Battery Replacement: passo 3, imagem 1 %32 Philips Sonicare ProtectiveClean 6500 Battery Replacement: passo 3, imagem 2 %32
    • Slide the internal assembly out of the chassis.
  4. Philips Sonicare ProtectiveClean 6500 Battery Replacement, Battery: passo 4, imagem 1 %32
    • Use an opening tool to gently pry up the battery.
    • Remove the battery.
Conclusão
Liam Casto
Membro desde: 04/01/24
354 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team 1-4, Harley Spring 2024 Membro de IUPUI, Team 1-4, Harley Spring 2024
IUPUI-HARLEY-S24S1G4
3 Membros
Autoria de 3 guias
2 comentários
Hello, thanks for your tutorial!
Is there others Sonicare models like this one where you don't have to desold the battery ?
Julien CHAZAL - Responder
It doesn’t appear you have to desolder the battery with this model. I think the diamond clean does require desoldering though.
Jacob Poole -
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 23
Ao todo: 260
