Ir para o conteúdo principal
Philips Sonicare Essence 1 Motherboard Replacement
O que você precisa
  1. Philips Sonicare Essence 1  Motherboard Replacement, Brush Head: passo 1, imagem 1 %32
    • Place one hand on the toothbrush handle and one on the toothbrush head.
  2. Philips Sonicare Essence 1  Motherboard Replacement: passo 2, imagem 1 %32
    • Separate the toothbrush head from the body by twisting it in a counter-clockwise direction.
  3. Philips Sonicare Essence 1  Motherboard Replacement, Front Handle Panel: passo 3, imagem 1 %32
    • Insert the spudger along the seem at the top of the panel.
    • Begin to pry open the panel.
  4. Philips Sonicare Essence 1  Motherboard Replacement: passo 4, imagem 1 %32
    • Insert the plastic pick at the top of the seam that has already been slightly pried open.
    • Continue down the seam, prying the rest of the panel open with the spudger.
  5. Philips Sonicare Essence 1  Motherboard Replacement, Motherboard: passo 5, imagem 1 %32
    • Apply a soldering iron to the mount-connectors and copper-wire connectors until the motherboard can be removed.
  6. Philips Sonicare Essence 1  Motherboard Replacement: passo 6, imagem 1 %32
    • Lift the motherboard straight up.
Conclusão
3 outras pessoas executaram este guia.
Equipe
IUPUI, Team S7-G1, Baechle Fall 2017 Membro de IUPUI, Team S7-G1, Baechle Fall 2017
IUPUI-BAECHLE-F17S7G1
Membros da 3
Autoria de 6 guias
2 comentários
Identification of the battery particulars would have been helpful to order replacement.
William Toperzer - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 22
Duração total: 1,525
