Ir para o conteúdo principal
Philips Sonicare DiamondClean Battery Replacement
O que você precisa
  1. Philips Sonicare DiamondClean Battery Replacement, Case Replacement: passo 1, imagem 1 %32 Philips Sonicare DiamondClean Battery Replacement, Case Replacement: passo 1, imagem 2 %32
    • Pull the head from toothbrush.
  2. Philips Sonicare DiamondClean Battery Replacement: passo 2, imagem 1 %32 Philips Sonicare DiamondClean Battery Replacement: passo 2, imagem 2 %32
    • Use a nylon spudger to pry the chrome cap at the bottom off.
  3. Philips Sonicare DiamondClean Battery Replacement: passo 3, imagem 1 %32
    • Use a nylon spudger to release the black tabs on either side of internals.
  4. Philips Sonicare DiamondClean Battery Replacement: passo 4, imagem 1 %32 Philips Sonicare DiamondClean Battery Replacement: passo 4, imagem 2 %32
    • Put the metal head on a solid surface with handle perpendicular to the surface. Firmly, yet gently, push down until the internals start to slide out.
  5. Philips Sonicare DiamondClean Battery Replacement, Battery: passo 5, imagem 1 %32
    • Remove rubber covers from the top of the motherboard and the back of the battery.
  6. Philips Sonicare DiamondClean Battery Replacement: passo 6, imagem 1 %32
    • Using a soldering iron, remove the solder from the three marked spots.
    • The pins are labeled "F1", "R6", "JP1"
  7. Philips Sonicare DiamondClean Battery Replacement: passo 7, imagem 1 %32
    • After de-soldering, the battery should be loose. If this is not the case, spend more time removing the solder.
    • When the battery comes loose, gently wiggle it out and away from the device.
  8. Philips Sonicare DiamondClean Battery Replacement: passo 8, imagem 1 %32
    • Carefully reinsert the new battery into the same spot as the old one. Gently press until it is firmly pressed against the toothbrush.
    • Green batteries have a black horizontal stripe at the top on the green wrap. That is the positive terminal that goes towards the top of the unit
  9. Philips Sonicare DiamondClean Battery Replacement: passo 10, imagem 1 %32
    • Apply a small amount of solder to the three points shown to attach the battery.
  10. Philips Sonicare DiamondClean Battery Replacement: passo 11, imagem 1 %32
    • Replace the rubber covers on the motherboard and battery.
    • Reverse the case replacement guide to finish putting the toothbrush back together.
Conclusão
7 outras pessoas executaram este guia.
Equipe
IUPUI, Team S22-G1, Bayer Fall 2017 Membro de IUPUI, Team S22-G1, Bayer Fall 2017
IUPUI-BAYER-F17S22G1
Membros da 4
Autoria de 9 guias
3 comentários
I recommend to soak the bottom of the brush in a cup of warm water to make it easier to remove the bottom cap. The plastic is very easy to crack when cold.
Janson McCreery - Responder
This is a decent guide. Thank you to the author! Problem is that they don't make these devices user serviceable, so we basically have to pry and force the cap off. ARGH! RIGHT TO REPAIR NOW!!
Maybe Dave - Responder
Die Anleitung ist bei Schrit 6 etwas irreführend, es sind nur 2 Lötstellen, die Batterie hat ja auch nur 2 Lötfahnen wie man sieht. Eine bei F1, die andere bei R6 und JP1. Der unterste Pfeil im Bild der auf JP1 zeigt ist falsch. Ich empfehle das Lötzinn mit einer Entlötpumpe mit Silikonspitze komplett zu entfernen da die Batterie in einer Kunststofffassung fest eingeklemmt ist und nur durch erhitzen des Lötzinns schwer herauszubekommen ist und sich direkt neben der unteren Lötstelle auch ein IC befindet sollte man beim löten sehr vorsichtig sein.
Michael - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 28
Últimos 7 dias: 173
Últimos 30 dias: 793
Duração total: 55,931
