Unplug the device and remove the purple guard. Remove the head by pressing the right side of the head (with the device facing away from you).
  • Unplug the device and remove the purple guard.
  • Remove the head by pressing the right side of the head (with the device facing away from you).
  • You will hear a 'click' and the head will become dislodged from the body of the device.
Adicionar comentário
While wearing safety glasses, use a plastic opening tool to pry from right to left to pry out the  tensor clip. Be careful not to lose the clip. It will likely fly off when it releases. Be careful not to lose the clip. It will likely fly off when it releases.
  • While wearing safety glasses, use a plastic opening tool to pry from right to left to pry out the tensor clip.
  • Be careful not to lose the clip. It will likely fly off when it releases.
The left side will swing down.
  • The left side will swing down.
  • Remove the Tweezers.
Remove the plastic component that swings down. Use fingernails to lift clips from stubs. Use fingernails to lift clips from stubs.
  • Remove the plastic component that swings down.
  • Use fingernails to lift clips from stubs.
Using Needle Nose pliers remove metal roller track on both sides of the Tweezers Head. Using Needle Nose pliers remove metal roller track on both sides of the Tweezers Head. Using Needle Nose pliers remove metal roller track on both sides of the Tweezers Head.
  • Using Needle Nose pliers remove metal roller track on both sides of the Tweezers Head.
Use a spudger to pry the gear housing unit from the base. Use a spudger to pry the gear housing unit from the base. Use a spudger to pry the gear housing unit from the base.
  • Use a spudger to pry the gear housing unit from the base.
Use your thumbnail and a pair of needle nose pliers to push out the gear housing retention pin. Use your thumbnail and a pair of needle nose pliers to push out the gear housing retention pin. Use your thumbnail and a pair of needle nose pliers to push out the gear housing retention pin.
  • Use your thumbnail and a pair of needle nose pliers to push out the gear housing retention pin.
Replace Tweezer Head. Ensure that the gear is inserted into the gear box end of the head.
  • Replace Tweezer Head.
  • Ensure that the gear is inserted into the gear box end of the head.
  • When closing the head, make sure that the Tweezer is seated correctly. To check this, the tweezers should spin fairly easily with the finger.
Conclusão
Nathan Christian
401 reputação
4 Guides authored
Equipe
IUPUI, Team S5-G5, Wilson Fall 2017 Membro de IUPUI, Team S5-G5, Wilson Fall 2017
IUPUI-WILSON-F17S5G5
3 Membros
5 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Todo: 50
