Introdução
Replace the epilator if the outer cover is so damaged that it becomes troublesome to hold. This is a very easy fix as it only requires you to transfer the components of the broken device into a new cover. You will need a metal spudger. Be careful not to damage any internal components as you pry apart the broken shell. This guide should take five to ten minutes to complete.
O que você precisa
To reassemble your device, move the components from the broken shell into the new shell and follow these instructions in reverse order.
