Ir para o conteúdo principal
Philips Satinelle On/Off Switch Replacement
O que você precisa
  1. Philips Satinelle On/Off Switch Replacement, Plastic Cover: passo 1, imagem 1 %32 Philips Satinelle On/Off Switch Replacement, Plastic Cover: passo 1, imagem 2 %32 Philips Satinelle On/Off Switch Replacement, Plastic Cover: passo 1, imagem 3 %32
    • Remove the head by pushing it to the right.
  2. Philips Satinelle On/Off Switch Replacement: passo 2, imagem 1 %32 Philips Satinelle On/Off Switch Replacement: passo 2, imagem 2 %32
    • Use a metal spudger to pry open the casing.
    • Caution: The epilator's internal components could be damaged if you shove the spudger in too far.
  3. Philips Satinelle On/Off Switch Replacement: passo 3, imagem 1 %32
    • Pull the plastic casing apart with your hands.
    • The plastic tab connecting the cover is likely going to break when you pull the device apart. This will not affect the operation of the epilator.
  4. Philips Satinelle On/Off Switch Replacement, On/Off Switch: passo 4, imagem 1 %32
    • Remove the green board and the black socket.
  5. Philips Satinelle On/Off Switch Replacement: passo 5, imagem 1 %32
    • Slide the switch down toward the socket.
  6. Philips Satinelle On/Off Switch Replacement: passo 6, imagem 1 %32 Philips Satinelle On/Off Switch Replacement: passo 6, imagem 2 %32 Philips Satinelle On/Off Switch Replacement: passo 6, imagem 3 %32
    • Put the components back into the frame
    • If the switch won't line up with the plastic square, make sure the large switch on the front of the operator is in the "off" position.
Conclusão
Uma outra pessoa concluiu este guia.
Riannon Varney
Membro desde: 10/08/18
168 Reputação
Autoria de 1 guia
Equipe
Marist, Team S1-G1, Chaterdon Fall 2018 Membro de Marist, Team S1-G1, Chaterdon Fall 2018
MARS-CHATERDON-F18S1G1
Membros da 3
Autoria de 4 guias
Um comentário
Very precise instructions, thanks!
carlos - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 49
Duração total: 1,493
