Ir para o conteúdo principal
Philips Satinelle Metal Rolling Tracks Replacement
O que você precisa
  1. Philips Satinelle Metal Rolling Tracks Replacement, Philips Satinelle Disassembly: passo 1, imagem 1 %32 Philips Satinelle Metal Rolling Tracks Replacement, Philips Satinelle Disassembly: passo 1, imagem 2 %32
    • Unplug the device and remove the purple guard.
    • Remove the head by pressing the right side of the head (with the device facing away from you).
    • You will hear a 'click' and the head will become dislodged from the body of the device.
  2. Philips Satinelle Metal Rolling Tracks Replacement: passo 2, imagem 1 %32 Philips Satinelle Metal Rolling Tracks Replacement: passo 2, imagem 2 %32 Philips Satinelle Metal Rolling Tracks Replacement: passo 2, imagem 3 %32
    • While wearing safety glasses, use a plastic opening tool to pry from right to left to pry out the tensor clip.
    • Be careful not to lose the clip. It will likely fly off when it releases.
  3. Philips Satinelle Metal Rolling Tracks Replacement: passo 3, imagem 1 %32
    • The left side will swing down.
    • Remove the Tweezers.
  4. Philips Satinelle Metal Rolling Tracks Replacement: passo 4, imagem 1 %32 Philips Satinelle Metal Rolling Tracks Replacement: passo 4, imagem 2 %32 Philips Satinelle Metal Rolling Tracks Replacement: passo 4, imagem 3 %32
    • Remove the plastic component that swings down.
    • Use fingernails to lift clips from stubs.
  5. Philips Satinelle Metal Rolling Tracks Replacement: passo 5, imagem 1 %32 Philips Satinelle Metal Rolling Tracks Replacement: passo 5, imagem 2 %32 Philips Satinelle Metal Rolling Tracks Replacement: passo 5, imagem 3 %32
    • Using Needle Nose pliers remove metal roller track on both sides of the Tweezers Head.
  6. Philips Satinelle Metal Rolling Tracks Replacement: passo 6, imagem 1 %32 Philips Satinelle Metal Rolling Tracks Replacement: passo 6, imagem 2 %32 Philips Satinelle Metal Rolling Tracks Replacement: passo 6, imagem 3 %32
    • Use a spudger to pry the gear housing unit from the base.
  7. Philips Satinelle Metal Rolling Tracks Replacement: passo 7, imagem 1 %32 Philips Satinelle Metal Rolling Tracks Replacement: passo 7, imagem 2 %32 Philips Satinelle Metal Rolling Tracks Replacement: passo 7, imagem 3 %32
    • Use your thumbnail and a pair of needle nose pliers to push out the gear housing retention pin.
  8. Philips Satinelle Metal Rolling Tracks Replacement, Metal Rolling Tracks Replacement: passo 8, imagem 1 %32
    • Replace Metal Roller Tracks on both sides of the Tweezer Head.
Conclusão
Nathan Christian
Membro desde: 11/11/17
505 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S5-G5, Wilson Fall 2017 Membro de IUPUI, Team S5-G5, Wilson Fall 2017
IUPUI-WILSON-F17S5G5
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 12
Duração total: 579
