Ir para o conteúdo principal
Philips Satinelle Gear Replacement
O que você precisa
  1. Philips Satinelle Gear Replacement, Philips Satinelle Disassembly: passo 1, imagem 1 %32 Philips Satinelle Gear Replacement, Philips Satinelle Disassembly: passo 1, imagem 2 %32
    • Unplug the device and remove the purple guard.
    • Remove the head by pressing the right side of the head (with the device facing away from you).
    • You will hear a 'click' and the head will become dislodged from the body of the device.
  2. Philips Satinelle Gear Replacement: passo 2, imagem 1 %32 Philips Satinelle Gear Replacement: passo 2, imagem 2 %32 Philips Satinelle Gear Replacement: passo 2, imagem 3 %32
    • While wearing safety glasses, use a plastic opening tool to pry from right to left to pry out the tensor clip.
    • Be careful not to lose the clip. It will likely fly off when it releases.
  3. Philips Satinelle Gear Replacement: passo 3, imagem 1 %32
    • The left side will swing down.
    • Remove the Tweezers.
  4. Philips Satinelle Gear Replacement: passo 4, imagem 1 %32 Philips Satinelle Gear Replacement: passo 4, imagem 2 %32 Philips Satinelle Gear Replacement: passo 4, imagem 3 %32
    • Remove the plastic component that swings down.
    • Use fingernails to lift clips from stubs.
  5. Philips Satinelle Gear Replacement: passo 5, imagem 1 %32 Philips Satinelle Gear Replacement: passo 5, imagem 2 %32 Philips Satinelle Gear Replacement: passo 5, imagem 3 %32
    • Using Needle Nose pliers remove metal roller track on both sides of the Tweezers Head.
  6. Philips Satinelle Gear Replacement: passo 6, imagem 1 %32 Philips Satinelle Gear Replacement: passo 6, imagem 2 %32 Philips Satinelle Gear Replacement: passo 6, imagem 3 %32
    • Use a spudger to pry the gear housing unit from the base.
  7. Philips Satinelle Gear Replacement: passo 7, imagem 1 %32 Philips Satinelle Gear Replacement: passo 7, imagem 2 %32 Philips Satinelle Gear Replacement: passo 7, imagem 3 %32
    • Use your thumbnail and a pair of needle nose pliers to push out the gear housing retention pin.
  8. Philips Satinelle Gear Replacement, Gear Replacement: passo 8, imagem 1 %32
    • Replace the gear and re-insert the pin.
    • Ensure that pin is protruding slightly, it should not be flush.
Conclusão
Nathan Christian
Membro desde: 11/11/17
505 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S5-G5, Wilson Fall 2017 Membro de IUPUI, Team S5-G5, Wilson Fall 2017
IUPUI-WILSON-F17S5G5
Membros da 3
Autoria de 4 guias
2 comentários
What size pinion is used in it? Kindly help.
Wilkis James - Responder
Can you send link to buy this piece?
Or 3d Printer file?
Thanks
Emilio Hernandez - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 30
Duração total: 1,307
