Ir para o conteúdo principal
Philips SBA1060 Capacitor Replacement
O que você precisa
  1. Philips SBA1060 Capacitor Replacement, Battery Casing: passo 1, imagem 1 %32
    • Remove the back cover by sliding it off.
    • Remove the 3 AAA batteries.
  2. Philips SBA1060 Capacitor Replacement: passo 2, imagem 1 %32 Philips SBA1060 Capacitor Replacement: passo 2, imagem 2 %32 Philips SBA1060 Capacitor Replacement: passo 2, imagem 3 %32
    • Unscrew the nine exterior screws on the back panel using a PH0-size Philips-head screwdriver.
    • A larger screwdriver head and more force may be required for damaged screws.
    • Remove the triangular end piece by pulling it straight off.
  3. Philips SBA1060 Capacitor Replacement: passo 3, imagem 1 %32 Philips SBA1060 Capacitor Replacement: passo 3, imagem 2 %32
    • Remove the colored grill by sliding it off in the direction of the removed end piece.
    • Pry off the back battery panel with the plastic opening tool.
    • Be careful to avoid tearing any wires.
  4. Philips SBA1060 Capacitor Replacement, Capacitor: passo 4, imagem 1 %32
    • Remove the two screws on opposite ends of the circuit board with the PH0 size philips head screw driver.
    • Slowly pull the circuit board out of the device
    • NOTE: Be careful not to damage any of the wires protruding from the back of the circuit board.
  5. Philips SBA1060 Capacitor Replacement: passo 5, imagem 1 %32 Philips SBA1060 Capacitor Replacement: passo 5, imagem 2 %32
    • Flip the device and remove the battery plug from the circuit board by pulling out the plugs to fully remove back panel.
    • Remove the speaker plugs from the circuit board by pulling out the plugs. They are located on opposite sides of the circuit board.
    • NOTE: When reassembling, note that the speaker with the red wire goes to the red plug, and the speaker with the white wire goes to the adjacent white plug.
    • Remove the light plug from the circuit board.
    • NOTE: This plug is twice as wide as the speaker and battery plugs.
  6. Philips SBA1060 Capacitor Replacement: passo 6, imagem 1 %32 Philips SBA1060 Capacitor Replacement: passo 6, imagem 2 %32
    • Locate the capacitor and carefully slide it out of the circuit board.
    • NOTE: The capacitor will be a cylindrical object protruding vertically near the center of the circuit board.
    • Slide the prongs of the replacement capacitor into the two holes of the circuit board where the original capacitor was removed from.
    • Reassemble the speaker.
Conclusão
April Driscoll
Membro desde: 10/21/13
321 Reputação
Autoria de 3 guias
Equipe
Clemson, Team 14-4, Benson Fall 2013 Membro de Clemson, Team 14-4, Benson Fall 2013
CLEM-BENSON-F13S14G4
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 6
Duração total: 732
