Introdução
This is a replacement guide for the fan in a Philips Respironics V60 ventilator. The cooling fan within the ventilator prevents the system from heating up too much. So it is important to ensure that this fan is kept clean and functioning.
For more information on replacing the fan, please refer to page 9-6 in the service manual.
O que você precisa
Press and release the ON/Shutdown key, opening the Shutdown window in the screen.
Select Ventilator Shutdown, which will shut down the ventilator.
Turn the captive D-ring fastener on the bottom of the panel counter-clockwise one-quarter turn and release.
Then remove the right side panel.
