Ir para o conteúdo principal
Philips Norelco Shaver Head Blade Replacement
O que você precisa
  1. Philips Norelco Shaver Head Blade Replacement, Philips Norelco Shaver Head Blade: passo 1, imagem 1 %32 Philips Norelco Shaver Head Blade Replacement, Philips Norelco Shaver Head Blade: passo 1, imagem 2 %32
    • Begin by pressing the small button beneath the head to allow it to open.
  2. Philips Norelco Shaver Head Blade Replacement: passo 2, imagem 1 %32 Philips Norelco Shaver Head Blade Replacement: passo 2, imagem 2 %32
    • Grasp the sides of the head and pull straight up to detach it from the body.
  3. Philips Norelco Shaver Head Blade Replacement: passo 3, imagem 1 %32 Philips Norelco Shaver Head Blade Replacement: passo 3, imagem 2 %32
    • To unlock, rotate the center locking mechanism counter-clockwise.
    Three blade head fit all shaver?
    Ronnie Kincaid - Responder
  4. Philips Norelco Shaver Head Blade Replacement: passo 4, imagem 1 %32
    • Lift the locking mechanism straight up, freeing the blades.
  5. Philips Norelco Shaver Head Blade Replacement: passo 5, imagem 1 %32 Philips Norelco Shaver Head Blade Replacement: passo 5, imagem 2 %32 Philips Norelco Shaver Head Blade Replacement: passo 5, imagem 3 %32
    • Carefully push the blades out from behind.
    • Although the blades are covered, they can fall apart, exposing sharp edges. Always use care when handling.
  6. Philips Norelco Shaver Head Blade Replacement: passo 6, imagem 1 %32 Philips Norelco Shaver Head Blade Replacement: passo 6, imagem 2 %32 Philips Norelco Shaver Head Blade Replacement: passo 6, imagem 3 %32
    • Insert the new blades, making sure to face the side with the two tabs towards the center of the head.
  7. Philips Norelco Shaver Head Blade Replacement: passo 7, imagem 1 %32 Philips Norelco Shaver Head Blade Replacement: passo 7, imagem 2 %32 Philips Norelco Shaver Head Blade Replacement: passo 7, imagem 3 %32
    • Line up the locking mechanism with the new blades, then rotate the center clockwise to lock down.
  8. Philips Norelco Shaver Head Blade Replacement: passo 8, imagem 1 %32 Philips Norelco Shaver Head Blade Replacement: passo 8, imagem 2 %32 Philips Norelco Shaver Head Blade Replacement: passo 8, imagem 3 %32
    • Push the head back onto the body, then close it up. Your shaver is good to go!
    Thanks so simple with your guide, cause I was really having hard time getting put back together right 👍
    Nate Cichy - Responder
Linha de Chegada
16 outras pessoas executaram este guia.
Austin Fisher
Membro desde: 09/29/15
518 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 10-1, Green Fall 2015 Membro de Cal Poly, Team 10-1, Green Fall 2015
CPSU-GREEN-F15S10G1
4 Membros
Autoria de 7 guias
9 comentários
This is a good guide thank you.
Replacing these shaver batteries would be a good guide: does anyone know how to do this?
Richard - Responder
Very well done - better than a video because you don’t need to continually stop, restart and rewind to catch specific details.
Clif T - Responder
The only problem I had was to insert the hinge into the body. Didn't want to push too hard as I was worried I could snap off some plastic parts. Once I had pushed the OLD unit on and off a couple of times the new one went in quite easily ( although the old unit was much more free than the new unit). Many thanks for your instructions - most useful!
Mike L. 14 March 2022
mike lowe - Responder
How do you change the trimmer blade on back of it ? Or can you ?
Melanie Gettys - Responder
Clear and simple tutorial. Excellent!
Greg Fullmer - Responder
Uh, how does one reset the cutter life timer? Many Norelco shavers have an annoying beep after so many hours of shaving to demand the cutters be replaced. Guessing the instructions in the new cutters say how to reset but that means I would have to purchase new cutters.
David kelly - Responder
Finally found the manual for my Series 8000. To reset the cutter life timer hold the power button for 7 seconds when turning the razor off. To lock the razor (for travel perhaps?) hold the power button for 3 seconds. Then 3 seconds at your destination to turn it on the first time.
What I have learned is if I go to the store (Walmart usually) , I find that the replacement shave blades and the replacement batteries cost more than buying a whole new razor. What's wrong with this picture.?
Ed Commons - Responder
I need to order #HQ56 replasments blades and cannot find the area to do that--Lynn Silsbee
Lynn Silsbee - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 45
Últimos 30 dias: 158
Ao todo: 47,820
