Ir para o conteúdo principal
Philips Norelco Shaver 2100 Battery Replacement
O que você precisa
  1. Philips Norelco Shaver 2100 Battery Replacement, Casing: passo 1, imagem 1 %32
    • Remove the single screw on the back casing using a T8 Torx screwdriver.
  2. Philips Norelco Shaver 2100 Battery Replacement: passo 2, imagem 1 %32 Philips Norelco Shaver 2100 Battery Replacement: passo 2, imagem 2 %32
    • Turn the shaver so that it is facing you.
    • Press the button on the shaver head to open it.
  3. Philips Norelco Shaver 2100 Battery Replacement: passo 3, imagem 1 %32
    • Remove the two 10.1 mm screws inside the shaver head using a T8 Torx screwdriver.
  4. Philips Norelco Shaver 2100 Battery Replacement: passo 4, imagem 1 %32 Philips Norelco Shaver 2100 Battery Replacement: passo 4, imagem 2 %32
    • Lift the shaver head off of the casing.
  5. Philips Norelco Shaver 2100 Battery Replacement: passo 5, imagem 1 %32 Philips Norelco Shaver 2100 Battery Replacement: passo 5, imagem 2 %32 Philips Norelco Shaver 2100 Battery Replacement: passo 5, imagem 3 %32
    • Gently pull the black and blue casing apart using a metal spudger.
  6. Philips Norelco Shaver 2100 Battery Replacement: passo 6, imagem 1 %32 Philips Norelco Shaver 2100 Battery Replacement: passo 6, imagem 2 %32 Philips Norelco Shaver 2100 Battery Replacement: passo 6, imagem 3 %32
    • Pry the remaining casing open using a metal spudger.
    • Be careful using a metal spudger, as it may result in damaging the case.
  7. Philips Norelco Shaver 2100 Battery Replacement, Battery: passo 7, imagem 1 %32 Philips Norelco Shaver 2100 Battery Replacement, Battery: passo 7, imagem 2 %32 Philips Norelco Shaver 2100 Battery Replacement, Battery: passo 7, imagem 3 %32
    • Remove the clear case that holds the circuit board by lifting the latches on the sides and then pulling gently.
  8. Philips Norelco Shaver 2100 Battery Replacement: passo 8, imagem 1 %32
    • Located directly behind the circuit board, remove the battery from the device.
Conclusão
11 outras pessoas executaram este guia.
Equipe
USF Tampa, Team S1-G4, Thompson Fall 2017 Membro de USF Tampa, Team S1-G4, Thompson Fall 2017
USFT-THOMPSON-F17S1G4
Membros da 3
Autoria de 5 guias
14 comentários
To remove the battery you have to actually desolder both ends from the chip.
AGUSTIN CABRA - Responder
What are the dimensions/specs of the battery?
Haley Pearse - Responder
regular AA rechargeable batteries will not work and can be a fire hazard.
steven - Responder
The tricky part is taking the case appart. You have to gently pry on tabs to get it appart. You may break some pieces which probably won’t be a problem. May make it no longer waterproof. The battery is custom but is close to a 14450 Lion battery, do searches on ebay and aliexpress you will find them. Good luck.
Don - Responder
I have a similar Norelco razor and replaced the battery. I can’t believe the stupid company didn’t mark the battery polarity on the board!
I think this is the first time I have ever seen a company not mark polarity.
Laz - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 38
Últimos 30 dias: 139
Duração total: 21,077
