Ir para o conteúdo principal
Philips Norelco OneBlade Servo Motor Replacement
O que você precisa
  1. Philips Norelco OneBlade Servo Motor Replacement, Servo Motor: passo 1, imagem 1 %32 Philips Norelco OneBlade Servo Motor Replacement, Servo Motor: passo 1, imagem 2 %32 Philips Norelco OneBlade Servo Motor Replacement, Servo Motor: passo 1, imagem 3 %32
    • Ensure razor is off and razor blade has been removed.
  2. Philips Norelco OneBlade Servo Motor Replacement: passo 2, imagem 1 %32 Philips Norelco OneBlade Servo Motor Replacement: passo 2, imagem 2 %32
    • Locate crease in bottom third of razor.
    • Hold razor in both hands, and place thumbs near crease.
    • Slightly bend the razor near crease.
    • Pull casing apart.
    • Device may turn on upon removal. Turn off razor before continuing.
  3. Philips Norelco OneBlade Servo Motor Replacement: passo 3, imagem 1 %32 Philips Norelco OneBlade Servo Motor Replacement: passo 3, imagem 2 %32 Philips Norelco OneBlade Servo Motor Replacement: passo 3, imagem 3 %32
    • Locate wires below motor on either side of circuit board.
    • Remove solder from each joint using solder removal kit.
    • Do not attempt to remove wires by force.
  4. Philips Norelco OneBlade Servo Motor Replacement: passo 4, imagem 1 %32
    • Remove new motor from package and place in position.
    • Motor should sit above circuit board with connection prongs facing downward. Additionally, center extrusion on bottom of motor should sit in provided hole.
Conclusão
Please dispose of servo motor properly. For recycling information, please contact your local waste management facilities or visit www.recycle.philips.com
5 outras pessoas executaram este guia.
Equipe
IUPUI, Team S3-G3, Harley Fall 2017 Membro de IUPUI, Team S3-G3, Harley Fall 2017
IUPUI-HARLEY-F17S3G3
Membros da 3
Autoria de 3 guias
10 comentários
does removing the motor exposing the battery? In my unit I see some green thing underneath the motor, looks like a AA battery, can you confirm?
or is it from somewhere else? (I need to replace my battery)
Yarden Cohen - Responder
I just dismantled my shaver, and it has a 1.2v AA size NiMH battery (suppo hsy aa1200).
João Paulo Gomes -
I’m also curious about the battery. Any one have pictures of it or know what kind of battery it has inside?
James Almeida - Responder
João Paulo Gomes -
Thanks! This definitely helps.
James Almeida -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 87
Duração total: 19,252
