Ir para o conteúdo principal
Philips Norelco MultiGroom 3100 Casing Replacement
O que você precisa
  1. Philips Norelco MultiGroom 3100 Casing Replacement, Power Button: passo 1, imagem 1 %32
    • Remove the comb from the top of the trimmer.
  2. Philips Norelco MultiGroom 3100 Casing Replacement: passo 2, imagem 1 %32 Philips Norelco MultiGroom 3100 Casing Replacement: passo 2, imagem 2 %32
    • Grip the attachment and twist it counterclockwise until you hear a click.
    • Pull the attachment up to remove it from the trimmer.
  3. Philips Norelco MultiGroom 3100 Casing Replacement: passo 3, imagem 1 %32 Philips Norelco MultiGroom 3100 Casing Replacement: passo 3, imagem 2 %32
    • Hold the trimmer upright so it is facing you.
    • Insert the plastic opening tool in the gap at the top of the power button.
  4. Philips Norelco MultiGroom 3100 Casing Replacement: passo 4, imagem 1 %32
    • Apply pressure to pry off the power button.
  5. Philips Norelco MultiGroom 3100 Casing Replacement, Casing: passo 5, imagem 1 %32 Philips Norelco MultiGroom 3100 Casing Replacement, Casing: passo 5, imagem 2 %32
    • Insert the spudger into the bottom of the gray bezel and begin to gently pry it off.
    • Separate the bezel one clip at a time so that the clips do not break.
  6. Philips Norelco MultiGroom 3100 Casing Replacement: passo 6, imagem 1 %32 Philips Norelco MultiGroom 3100 Casing Replacement: passo 6, imagem 2 %32
    • Insert the spudger in the indicated hole and apply a tilting force to loosen the outer casing.
    • Pull upward on the top of the inner housing to remove it from the outer casing.
Conclusão
9 outras pessoas executaram este guia.
ahaharevolution
Membro desde: 10/04/15
759 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 1-1, Leahy Fall 2015 Membro de USF Tampa, Team 1-1, Leahy Fall 2015
USFT-LEAHY-F15S1G1
Membros da 2
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 28
Duração total: 4,972
