Ir para o conteúdo principal
Philips Norelco BeardTrimmer 3100 Power Switch Replacement
O que você precisa
  1. Philips Norelco BeardTrimmer 3100 Power Switch Replacement, Front and Back Panels: passo 1, imagem 1 %32
    • Remove the comb from the top of the trimmer.
  2. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: passo 2, imagem 1 %32 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: passo 2, imagem 2 %32
    • Place your thumb underneath the blade and push upward to remove it.
  3. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: passo 3, imagem 1 %32 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: passo 3, imagem 2 %32
    • Hold trimmer towards you as shown in the diagram.
    • Insert your prying tool/metal spudger into the marked area.
  4. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: passo 4, imagem 1 %32 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: passo 4, imagem 2 %32 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: passo 4, imagem 3 %32
    • Apply gentle pressure and begin prying open the back panel.
    • Separate the panel one notch at a time. Listen carefully as you're prying the panel apart and notice each individual notch release.
  5. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: passo 5, imagem 1 %32 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: passo 5, imagem 2 %32 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: passo 5, imagem 3 %32
    • Pull the trimmer apart using your hands once the panel is at least halfway apart.
    • Pull the wires attached to the battery off of the power connectors before completely removing the back panel.
  6. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: passo 6, imagem 1 %32 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: passo 6, imagem 2 %32
    • Hold the trimmer towards you.
    • Place the metal spudger tool in the marked area.
  7. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: passo 7, imagem 1 %32
    • Apply gentle pressure and begin prying the front panel.
    • Separate the front panel one notch at a time.
  8. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: passo 8, imagem 1 %32 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: passo 8, imagem 2 %32
  9. Philips Norelco BeardTrimmer 3100 Power Switch Replacement, Power Switch: passo 9, imagem 1 %32
    • Remove the front panel completely from the rest of the beard trimmer.
  10. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: passo 10, imagem 1 %32
    • Rotate the front panel so that the power switch is facing away from you.
  11. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: passo 11, imagem 1 %32 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: passo 11, imagem 2 %32 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: passo 11, imagem 3 %32
    • Push the white plastic frame upward to remove it from the notch.
    • Pull the white plastic frame off the front panel of the beard trimmer.
  12. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: passo 12, imagem 1 %32
    • Remove the power switch from the front panel once the white plastic frame is removed.
Conclusão
Tamara Titus
Membro desde: 09/03/15
133 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 15-2, Blackwell Fall 2015 Membro de USF Tampa, Team 15-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G2
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 42
Duração total: 5,801
