Introdução
If the blades of your beard trimmer are not working properly, there could be too much hair/dirt between the blades or the blade may have become worn out over time. The blade may need replacement. By following the steps in this guide you will have a new blade installed in no time.
O que você precisa
21 outras pessoas executaram este guia.
10 comentários
what about getting it back togeather
Sadly it is impossible to put the parts back together. It isnt just as simple as start with the end. Normally i am quite good with fixing stuff. But this time... maybe because mine is broken? A guide for putting it back together should show me where it g9es wrong. But thanks for the guide anyways, thanks for the time you put into it.
Now I can't get it back :-(
It's easy to get it back.i assembled mine a lot of times... Guys just try
The only difficult part is the spring... Just pay attention to details and use something to hold the spring from within
where can i find blade for trimmer ??
It's bit tough to re fix it.. however I done it in 15min try without any special tool..
First fix the basic assembly from bottom to top. Finally fix the tension spring with your finger by pushing it on the lock..
Try it once or twice, you can do it..
Spring is a nightmare.
Well I could reassemble mine. Just use your common sense to put the parts back together.
