Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Place your thumb underneath the blade and push upward to remove it.
Hold trimmer towards you as shown in the diagram.
Insert your prying tool/metal spudger into the marked area.
Apply gentle pressure and begin prying open the back panel.
Separate the panel one notch at a time. Listen carefully as you're prying the panel apart and notice each individual notch release.
Pull the trimmer apart using your hands once the panel is at least halfway apart.
Pull the wires attached to the battery off of the power connectors before completely removing the back panel.
Hold the trimmer towards you.
Place the metal spudger tool in the marked area.
Apply gentle pressure and begin prying the front panel.
Separate the front panel one notch at a time.
Face the battery towards you.
Locate the power connectors on the bottom of the trimmer, pull them from the base with your spudger.
Grab the battery by its sides, pull it upwards out of the base of the trimmer.
Locate the connection between the blue wire and the battery. Melt the solder and completely remove the battery.
29 outras pessoas executaram este guia.
20 comentários
Hi, what are the specs on the NiMh battery?
NiMh AA 1650 mAh 1.2V rechargeable battery. Search Amazon.com for philips norelco qt4022 battery. One result is UPC 737212062822
I think you can simply use a AA battery, 1.2V
Note: AA Alkaline battery is 1.5V and not rechargeable.
Awesome work.very helpful
