Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
When the battery dies completely and no longer holds a charge, this guide will illustrate the proper way of removing the battery for replacement. CAUTION. Please do not throw away the dead battery in the trash. See a proper disposal center for any handling of dead batteries.
O que você precisa
Face the battery towards you.
Locate the power connectors on the bottom of the trimmer, pull them from the base with your spudger.
29 outras pessoas executaram este guia.
20 comentários
Hi, what are the specs on the NiMh battery?
NiMh AA 1650 mAh 1.2V rechargeable battery. Search Amazon.com for philips norelco qt4022 battery. One result is UPC 737212062822
I think you can simply use a AA battery, 1.2V
Note: AA Alkaline battery is 1.5V and not rechargeable.
Awesome work.very helpful
