Introdução
This guide will show how to take out a broken motor, and replace it with a new one. You may need this if either the trimmer or shaver head on the Philips Norelco Bodygroom stop working due to motor malfunctions. It is also necessary for this guide to show how to disassemble and reassemble the trimmer in order to get to the motors. It is recommended to have the iFixit Pro Tech Toolkit since it will contain all tools necessary for this guide. Lastly, you will need to provide your own working motor to replace the broken one.
O que você precisa
Using the spudger, unclip the plastic housing around white casing.
Remove one half of the black housing first, and then proceed to the next half.
