Ir para o conteúdo principal
Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement
O que você precisa
  1. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement, LED Board: passo 1, imagem 1 %32 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement, LED Board: passo 1, imagem 2 %32
    • Place thumb behind trimming blade and push up to open.
  2. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: passo 2, imagem 1 %32 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: passo 2, imagem 2 %32 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: passo 2, imagem 3 %32
    • Remove two screws (M2 x 9.5) on metal plate with JIS 0 screwdriver bit.
    • Use spudger to pry off metal plate.
    • Slide up plastic housing to remove the trimmer.
  3. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: passo 3, imagem 1 %32 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: passo 3, imagem 2 %32 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: passo 3, imagem 3 %32
    • Slide chrome outer plastic towards removed trimmer.
    • Flip to the other side and repeat, sliding the chrome plastic towards removed trimmer.
  4. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: passo 4, imagem 1 %32 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: passo 4, imagem 2 %32
    • Remove two top screws (M2 x 6.9) with the JIS 00 screwdriver bit.
    • Remove two bottom screws (M2 x 6.9) with the same bit.
  5. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: passo 5, imagem 1 %32 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: passo 5, imagem 2 %32 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: passo 5, imagem 3 %32
    • Use spudger to pry off top of the battery cover. WARNING: fairly difficult, be aware significant amount of force required.
    • Use spudger to remove bottom of the battery cover, and remove it.
  6. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: passo 6, imagem 1 %32 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: passo 6, imagem 2 %32
    • Use a nylon spudger to pry out battery pack and the attached LED board.
  7. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: passo 7, imagem 1 %32 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: passo 7, imagem 2 %32 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: passo 7, imagem 3 %32
    • Unwrap electrical tape around the battery pack and LED board.
    • Desolder the LED board from the battery pack.
    • Solder the new LED board back to the connection to battery pack.
Conclusão
August Post
Membro desde: 11/07/17
415 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S2-G4, Harley Fall 2017 Membro de IUPUI, Team S2-G4, Harley Fall 2017
IUPUI-HARLEY-F17S2G4
Membros da 3
Autoria de 4 guias
Um comentário
Can you point me in the right direction for finding a replacement board? I’m having trouble finding one. Thanks.
Alex - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 547
