Ir para o conteúdo principal
Philips DVP5992-F7 USB port Replacement
O que você precisa
  1. Philips DVP5992-F7 USB port Replacement, USB port: passo 1, imagem 1 %32 Philips DVP5992-F7 USB port Replacement, USB port: passo 1, imagem 2 %32 Philips DVP5992-F7 USB port Replacement, USB port: passo 1, imagem 3 %32
    • Remove the three 6.4 mm Phillips #1 screws on the back of the device with a Phillips head screwdriver.
    • Remove the 6.4 mm Phillips #1 screws on each side of the device.
  2. Philips DVP5992-F7 USB port Replacement: passo 2, imagem 1 %32 Philips DVP5992-F7 USB port Replacement: passo 2, imagem 2 %32
    • Remove the top plate of the DVD by firmly grasping the player on both sides.
    • Shift the top plate towards the backside of the player.
    • Lift the back half of the top plate up to remove it from the player.
  3. Philips DVP5992-F7 USB port Replacement: passo 3, imagem 1 %32 Philips DVP5992-F7 USB port Replacement: passo 3, imagem 2 %32 Philips DVP5992-F7 USB port Replacement: passo 3, imagem 3 %32
    • Locate the bundled cable connectors that attaches the USB port to the motherboard.
    • Firmly grasp the bundled cable connector and lift it from the motherboard.
  4. Philips DVP5992-F7 USB port Replacement: passo 4, imagem 1 %32 Philips DVP5992-F7 USB port Replacement: passo 4, imagem 2 %32
    • Locate the area behind the USB port within the interior of the DVD Player.
    • Unscrew the two 6.35 mm Phillips #1 screws located behind the USB port.
  5. Philips DVP5992-F7 USB port Replacement: passo 5, imagem 1 %32 Philips DVP5992-F7 USB port Replacement: passo 5, imagem 2 %32
    • Use the plastic opening tool to press down on the brass clip that holds the USB port in place.
    • Pull back the USB Port to remove it from the DVD player.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 16
Duração total: 549
