Introdução
This project will involve working around delicate electrical components so it is important to be very careful that you not damage any of these components as it may cause your DVD player to not work properly.
O que você precisa
Remove the three 6.4 mm Phillips #1 screws on the back of the device with a Phillips head screwdriver.
Remove the 6.4 mm Phillips #1 screws on each side of the device.
Unplug the bundled cable connector that attaches the screen to the motherboard.
Remove the 3.175 mm Phillips #1 screw that connects the screen's ground wire to the shell of the DVD player.
Remove the three 6.35 mm Phillips #1 screws that attach the screen to the front cover of the DVD player.
