Ir para o conteúdo principal
Philips DVP5992-F7 Power Cord Replacement
O que você precisa
  1. Philips DVP5992-F7 Power Cord Replacement, Power Cord: passo 1, imagem 1 %32 Philips DVP5992-F7 Power Cord Replacement, Power Cord: passo 1, imagem 2 %32 Philips DVP5992-F7 Power Cord Replacement, Power Cord: passo 1, imagem 3 %32
    • Remove the three 6.4 mm Phillips #1 screws on the back of the device with a Phillips head screwdriver.
    • Remove the 6.4 mm Phillips #1 screws on each side of the device.
  2. Philips DVP5992-F7 Power Cord Replacement: passo 2, imagem 1 %32 Philips DVP5992-F7 Power Cord Replacement: passo 2, imagem 2 %32
    • Remove the top plate of the DVD by firmly grasping the player on both sides.
    • Shift the top plate towards the backside of the player.
    • Lift the back half of the top plate up to remove it from the player.
  3. Philips DVP5992-F7 Power Cord Replacement: passo 3, imagem 1 %32 Philips DVP5992-F7 Power Cord Replacement: passo 3, imagem 2 %32 Philips DVP5992-F7 Power Cord Replacement: passo 3, imagem 3 %32
    • Locate the power cable connector inside the DVD player.
    • Pinch down on both sides of the cable connector.
    • Gently pull upwards on the cable connector while wiggling it to remove it from the DVD player.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 12
Duração total: 392
