Ir para o conteúdo principal
Philips DVP5992-F7 HDMI port Replacement
O que você precisa
  1. Philips DVP5992-F7 HDMI port Replacement, HDMI port: passo 1, imagem 1 %32 Philips DVP5992-F7 HDMI port Replacement, HDMI port: passo 1, imagem 2 %32 Philips DVP5992-F7 HDMI port Replacement, HDMI port: passo 1, imagem 3 %32
    • Remove the three 6.4 mm Phillips #1 screws on the back of the device with a Phillips head screwdriver.
    • Remove the 6.4 mm Phillips #1 screws on each side of the device.
  2. Philips DVP5992-F7 HDMI port Replacement: passo 2, imagem 1 %32 Philips DVP5992-F7 HDMI port Replacement: passo 2, imagem 2 %32
    • Remove the top plate of the DVD by firmly grasping the player on both sides.
    • Shift the top plate towards the backside of the player.
    • Lift the back half of the top plate up to remove it from the player.
  3. Philips DVP5992-F7 HDMI port Replacement: passo 3, imagem 1 %32 Philips DVP5992-F7 HDMI port Replacement: passo 3, imagem 2 %32 Philips DVP5992-F7 HDMI port Replacement: passo 3, imagem 3 %32
    • Unplug the one ribbon wire and the five bundled cable connectors that are plugged into the motherboard.
  4. Philips DVP5992-F7 HDMI port Replacement: passo 4, imagem 1 %32
    • Remove the three 4.76 mm #1 Phillips head screws located on the back of the DVD player.
  5. Philips DVP5992-F7 HDMI port Replacement: passo 5, imagem 1 %32
    • Remove the two 7.94 mm #1 Phillips head screws from the motherboard.
  6. Philips DVP5992-F7 HDMI port Replacement: passo 6, imagem 1 %32
    • Remove the motherboard from the DVD player.
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 10
Ao todo: 440
