Introdução
Ensure to have a new/flawless motherboard lying next to you before you start removing the defective one.
You should also have a little bowl ready to set aside screws and other small parts.
O que você precisa
Put on the Anti-Static Wrist Strap and clamp the end of the band to an unpaintet spot of a radiator.
Unscrew the six Torx #4 (5,3 mm) screws from both sides of the device
Unscrew the eight Torx #4 (5,0 mm) screws from the motherboard.
These two screws connect the motherboard with the sliding cage. In this guide they are removed as well. Hence this is not compulsory you can decide for yourself whether you want to remove them now or later.
Uma outra pessoa concluiu este guia.
