Introdução
Follow the procedure in this guide to remove and install a broken LCD screen.
O que você precisa
Pry off the four white feet with the pointed end of the spudger
Unscrew the seven 6 mm Phillips #00 screws holding the grey side piece to the black front panel.
Unscrew the two 8 mm Phillips #1 screws that go through the grey piece and the LCD motherboard.
Quase terminado!
Conclusão
