Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Pry off the four white feet with the pointed end of the spudger
Gently unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
Carefully pull up and out the four electrical connectors and two ribbon connectors that connect the bottom panel to the dock.
Electrical Connectors
Ribbon Connectors
Pull the copper plate out of the way of the two Phillips #00 screws in the middle of the connector.
Unscrew the two 7 mm Phillips #00 screws holding the connector together.
Unscrew the four 5 mm Phillips #00 screws holding the connector to the dock
Pull out the black U-shaped piece.
Pull out the iPhone/iPod support cradle.
Pull out the two springs.
Pop out the black connector frame and attached circuit board from the body of the dock.
