Ir para o conteúdo principal
Philips DC320 37 Connector Replacement
O que você precisa
  1. Philips DC320 37 Connector Replacement, Docking entertainment system: passo 1, imagem 1 %32
    • Pry off the four white feet with the pointed end of the spudger
  2. Philips DC320 37 Connector Replacement: passo 2, imagem 1 %32
    • Gently unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
  3. Philips DC320 37 Connector Replacement: passo 3, imagem 1 %32
    • Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
    • The connectors on the panel are fragile and may break.
  4. Philips DC320 37 Connector Replacement: passo 4, imagem 1 %32 Philips DC320 37 Connector Replacement: passo 4, imagem 2 %32 Philips DC320 37 Connector Replacement: passo 4, imagem 3 %32
    • Carefully pull up and out the four electrical connectors and two ribbon connectors that connect the bottom panel to the dock.
    • Electrical Connectors
    • Ribbon Connectors
    • The cables do not have a lot of slack in them. Be careful not to break the connectors.
    • One wire is soldered onto the bottom panel. Be careful not to break this bond.
  5. Philips DC320 37 Connector Replacement, Connector: passo 5, imagem 1 %32
    • Pull the copper plate out of the way of the two Phillips #00 screws in the middle of the connector.
  6. Philips DC320 37 Connector Replacement: passo 6, imagem 1 %32
    • Unscrew the two 7 mm Phillips #00 screws holding the connector together.
    • Unscrew the four 5 mm Phillips #00 screws holding the connector to the dock
  7. Philips DC320 37 Connector Replacement: passo 7, imagem 1 %32 Philips DC320 37 Connector Replacement: passo 7, imagem 2 %32 Philips DC320 37 Connector Replacement: passo 7, imagem 3 %32
    • Turn the dock so that you are looking at the front of the dock.
    • Pull out the black U-shaped piece.
    • Pull out the iPhone/iPod support cradle.
    • Pull out the two springs.
  8. Philips DC320 37 Connector Replacement: passo 8, imagem 1 %32
    • Turn the dock so that you are looking at the bottom of the dock.
    • Pop out the black connector frame and attached circuit board from the body of the dock.
Conclusão
Greg Lane
Membro desde: 04/16/13
39 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 3-48, Amido Spring 2013 Membro de Cal Poly, Team 3-48, Amido Spring 2013
CPSU-AMIDO-S13S3G48
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 8
Duração total: 1,234
