Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
Follow the procedure outlined in this guide to remove and install the circuit board for the device's bottom buttons.
  1. Pry off the four white feet with the pointed end of the spudger
    • Pry off the four white feet with the pointed end of the spudger
  2. Unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
    • Unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
  3. Kit de ferramentas básico para eletrônica
    Kit pequeno. Grandes possibilidades.
    Shop Toolkits
    Kit de ferramentas
    básico para
    eletrônica
    Shop Toolkits
  4. Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
    • Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
    • The connectors on the panel are fragile and may break.
  5. Carefully pull up and out the four electrical connectors and the two ribbon connectors connecting the bottom panel and the dock. Electrical Connectors Ribbon Connectors
    • Carefully pull up and out the four electrical connectors and the two ribbon connectors connecting the bottom panel and the dock.
    • Electrical Connectors
    • Ribbon Connectors
    • The cables do not have a lot of slack in them. Be careful not to break the connectors.
    • One wire is soldered onto the bottom panel. Be careful not to break this bond.
  6. Unscrew the ten 6 mm Phillips #00 screws holding the board in place.
    • Unscrew the ten 6 mm Phillips #00 screws holding the board in place.
  7. Pull the board out from the dock
    • Pull the board out from the dock
Conclusão
Greg Lane
Membro desde: 16-04-2013
9 Reputação
4 Guias de autoria
Equipe
Cal Poly, Team 3-48, Amido Spring 2013 Membro de Cal Poly, Team 3-48, Amido Spring 2013
CPSU-AMIDO-S13S3G48
4 Membros
6 Guias de autoria
My philips dc 320 /37 A do not sown time digits and frecvency digits . Where can I find schematic diagram?
Thank you
chioreangheorghe - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 711
