Ir para o conteúdo principal
Philips BiPAP S/T Humidifier Replacement
Equipamento Médico
Nem o iFixit nem este guia de reparo são endossados ou afiliados ao fabricante do dispositivo médico.
O que você precisa
  1. Philips BiPAP S/T Humidifier Replacement, Humidifier: passo 1, imagem 1 %32
    • Remove the Water Chamber Assembly.
    • Gently squeeze the latch on the Flip Lid Assembly to release it.
    • Lift the Flip Lid Assembly.
    • Pull the Humidifier Tank Assembly out of the Humidifier.
  2. Philips BiPAP S/T Humidifier Replacement: passo 2, imagem 1 %32
    • Remove the Tank Top Seal from the Flip Lid Assembly.
    • If this is the source of the error, put in a new one.
  3. Philips BiPAP S/T Humidifier Replacement: passo 3, imagem 1 %32 Philips BiPAP S/T Humidifier Replacement: passo 3, imagem 2 %32
    • Remove the Dry Box Seal.
    • If this is the source of error, place this part with a new one.
    • When replacing, ensure that the narrow end of the seal is inserted into the Dry Box.
  4. Philips BiPAP S/T Humidifier Replacement: passo 4, imagem 1 %32 Philips BiPAP S/T Humidifier Replacement: passo 4, imagem 2 %32
    • Remove the Dry Box Assembly.
    • Insert a flat blade screwdriver into the hole located on the back of the Humidifier and lightly press inward to release the Dry Box Assembly.
    • Do not press firmly on the screwdriver as damage may occur.
    • Remove the Inlet Seal from the Dry Box Assembly
  5. Philips BiPAP S/T Humidifier Replacement: passo 5, imagem 1 %32 Philips BiPAP S/T Humidifier Replacement: passo 5, imagem 2 %32 Philips BiPAP S/T Humidifier Replacement: passo 5, imagem 3 %32
    • Remove the Flip Lid Assembly.
    • Use a screwdriver to push in on the latches that secure the Flip Lid Assembly to the Humidifier Top Housing.
    • Bend the Flip Lid Assembly completely backwards until it is removed.
    • For Heated Tube devices, remove the wire harness from the base.
  6. Philips BiPAP S/T Humidifier Replacement: passo 6, imagem 1 %32
    • Use a T8 Torx screwdriver to remove the four #4 x 1/2" screws that secure the Top Housing to the Humidifier Bottom Housing
  7. Philips BiPAP S/T Humidifier Replacement: passo 7, imagem 1 %32
    • Slide the Outside Cover out of the Bottom Housing.
  8. Philips BiPAP S/T Humidifier Replacement: passo 8, imagem 1 %32
    • Remove the Left Side Panel.
    • Use a T15 Torx screwdriver to remove the four #6 x 1/4" screws that secure the Bottom Housing to the Lower Base Assembly.
  9. Philips BiPAP S/T Humidifier Replacement: passo 9, imagem 1 %32 Philips BiPAP S/T Humidifier Replacement: passo 9, imagem 2 %32
    • Remove the Heater Plate Assembly.
    • The Heater Plate Assembly is secured by two small tabs.
    • Once replaced, secure the Bottom Housing to the Lower Base using the four #6 x 1/4" screws.
    • Be sure the Heater Plate Spring is properly seated under the Heater Plate.
Conclusão
Courtney Huitt
Membro desde: 04/07/20
169 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S7-G3, Paton Spring 2020 Membro de Cal Poly, Team S7-G3, Paton Spring 2020
CPSU-PATON-S20S7G3
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 302
