Ir para o conteúdo principal
Philips BiPAP S/T Blower Replacement
Equipamento Médico
Nem o iFixit nem este guia de reparo são endossados ou afiliados ao fabricante do dispositivo médico.
O que você precisa
Vídeo de Apresentação
  1. Philips BiPAP S/T Blower  Replacement, Blower: passo 1, imagem 1 %32
    • Remove the UI Knob by pulling it straight out.
  2. Philips BiPAP S/T Blower  Replacement: passo 2, imagem 1 %32
    • Remove the top cover by using a Torx T15 to remove the 2 screws on the back of the enclosure.
  3. Philips BiPAP S/T Blower  Replacement: passo 3, imagem 1 %32
    • Remove the Main PCA by removing the wiring harnesses and squeezing the 2 standoffs in the corners of the board.
  4. Philips BiPAP S/T Blower  Replacement: passo 4, imagem 1 %32
    • Remove the Blower Cap by using the T8 Torx screwdriver to remove the 7 screws that secure the Cap to the enclosure.
    • Lift the Blower Assembly out of the blower housing.
    • Remove the blower Outlet Bellows from the blower assembly.
    • Place the New outlet bellows onto the blower assembly.
  5. Philips BiPAP S/T Blower  Replacement: passo 7, imagem 1 %32
    • Align the stands located on the bottom of the blower assembly with the holes in the blower housing.
Conclusão
Equipe
Cal Poly, Team S7-G3, Paton Spring 2020 Membro de Cal Poly, Team S7-G3, Paton Spring 2020
CPSU-PATON-S20S7G3
Membros da 3
Autoria de 3 guias
Um comentário
this was super helpful. i yanked a working motor/blower from a slightly older system one unit that had a dead humidifier circuit(found it had melted the connector inside) and moved it to my newer bipap unit. works great, dead silent. mine had bad bearings…so loud. great article. thank you for saving me money, time…..SLEEP!
Jon Harmon - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 11
Duração total: 2,800
