Introdução
The most common issue with humming, and intermittent failure to come on, is a failed transformer. The part number for the transformer is LTT2PC0XB044. The least expensive one I found was $11. This set opens up without any difficulties, the layout of the PCB's is clean and neat. Philips was kind enough, to mark the screws that need to be removed, with an arrow on the circuit board.
O que você precisa
Here is the Philips 22PFL3504D. Fingerprints are definitely visible on the glossy front bezel and the LCD. those are really just smudges.
Turn the TV over and lay it down,
this will show the four Philips head screws that hold the base on to the TV
Insert the new transformer gently through the holes on the board.
Turn the logic board component side down, identify the transformer contacts. Apply some flux to the contacts.
Solder the new transformer in place. The brownish residue is from the flux. The board can be cleaned with isopropyl alcohol after the solder repair.
4 outras pessoas executaram este guia.
2 comentários
What was the problem with the tv? How did you know that the problem was the transfomer?
The transformer had a “bad" humming sound, explained in the text ;-)
