Ir para o conteúdo principal
Petzl E03 050 Headlamp Battery Replacement
O que você precisa
  1. Petzl E03 050 Headlamp Battery Replacement, Remove the Cover: passo 1, imagem 1 %32
    • Remove the back cover of the battery housing (found behind the mount assembly) by pulling the small tab on the bottom right corner.
  2. Petzl E03 050 Headlamp Battery Replacement, Remove the Old Batteries: passo 2, imagem 1 %32
    • Remove the old batteries by pulling outward the positive end of each battery.
  3. Petzl E03 050 Headlamp Battery Replacement, Insert the New Batteries: passo 3, imagem 1 %32
    • Insert the new batteries by inserting the negative end of the battery into the negative side of the battery compartment and pushing the positive end of the battery into the positive side of battery compartment.
  4. Petzl E03 050 Headlamp Battery Replacement, Reattach the Cover: passo 4, imagem 1 %32
    • Reattach the back cover of the battery housing by pushing in the bottom half and then pressing the rest of the cover into place.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Mike
Membro desde: 10/23/14
331 Reputação
Autoria de 3 guias
Equipe
Baylor, Team 8-10, Williams Fall 2014 Membro de Baylor, Team 8-10, Williams Fall 2014
BU-WILLIAMS-F14S8G10
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 19
Últimos 30 dias: 90
Duração total: 5,264
