Ir para o conteúdo principal
Petnet SmartFeeder SF10E Motherboard Replacement
O que você precisa
  1. Petnet SmartFeeder SF10E Motherboard Replacement, Battery: passo 1, imagem 1 %32 Petnet SmartFeeder SF10E Motherboard Replacement, Battery: passo 1, imagem 2 %32 Petnet SmartFeeder SF10E Motherboard Replacement, Battery: passo 1, imagem 3 %32
    • Eject the SmartBowl by pressing the button located at the front of the SmartFeeder base.
    • Remove the metal tray by using both hands and pulling out the bowl towards you.
  2. Petnet SmartFeeder SF10E Motherboard Replacement: passo 2, imagem 1 %32 Petnet SmartFeeder SF10E Motherboard Replacement: passo 2, imagem 2 %32
    • Turn the bowl tray side down by using both hands.
    • Remove seven 11 mm screws by using the Phillips #1 screwdriver.
  3. Petnet SmartFeeder SF10E Motherboard Replacement: passo 3, imagem 1 %32 Petnet SmartFeeder SF10E Motherboard Replacement: passo 3, imagem 2 %32
    • Take the battery out of the SmartBowl with tweezers, avoid pulling on any wires.
    • Hold the SmartBowl down using one hand while using the other hand to remove the battery.
  4. Petnet SmartFeeder SF10E Motherboard Replacement: passo 4, imagem 1 %32 Petnet SmartFeeder SF10E Motherboard Replacement: passo 4, imagem 2 %32
    • Remove the tape, closest to the four white connectors, with your hands.
    • Keep the wires attached to the tape for easy reassembly.
  5. Petnet SmartFeeder SF10E Motherboard Replacement: passo 5, imagem 1 %32 Petnet SmartFeeder SF10E Motherboard Replacement: passo 5, imagem 2 %32
    • Trace the wires with your hands from the battery to the motherboard.
    • Detach the three-prong connector between the battery and the motherboard by pulling the white connectors with your hands.
    • Hold on to the sockets on the motherboard or you could accidentally pull off the entire assembly.
  6. Petnet SmartFeeder SF10E Motherboard Replacement, Motherboard: passo 6, imagem 1 %32
    • Remove the remaining 3-prong connectors by carefully pulling outwards.
  7. Petnet SmartFeeder SF10E Motherboard Replacement: passo 7, imagem 1 %32 Petnet SmartFeeder SF10E Motherboard Replacement: passo 7, imagem 2 %32
    • Push both small gray pieces next to the ribbon connector towards the ribbon to put them in the “open” position using the nylon spudger.
  8. Petnet SmartFeeder SF10E Motherboard Replacement: passo 8, imagem 1 %32 Petnet SmartFeeder SF10E Motherboard Replacement: passo 8, imagem 2 %32
    • Remove the ribbon connector from its slot by pulling on it with a couple fingers.
    • The ribbon should come out easily with the gray pieces in the "open" position. Do not use too much force with the ribbon or it could be damaged.
    • Make sure the gray pieces are in the “open” position when you reassemble the ribbon connector or the connector will not go into its slot. Once the connector is in the slot, slide the gray tabs back down into the “closed” position
Conclusão
Travis Lamb
Membro desde: 10/08/18
100 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S13-G7, White Fall 2018 Membro de Cal Poly, Team S13-G7, White Fall 2018
CPSU-WHITE-F18S13G7
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 348
