Ir para o conteúdo principal
Petnet SmartFeeder SF10E 12 Pin Connector Replacement
O que você precisa
  1. Petnet SmartFeeder SF10E 12 Pin Connector Replacement, 12 Pin Connector: passo 1, imagem 1 %32 Petnet SmartFeeder SF10E 12 Pin Connector Replacement, 12 Pin Connector: passo 1, imagem 2 %32 Petnet SmartFeeder SF10E 12 Pin Connector Replacement, 12 Pin Connector: passo 1, imagem 3 %32
    • Eject the SmartBowl by pressing the button located at the front of the SmartFeeder base.
  2. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: passo 2, imagem 1 %32 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: passo 2, imagem 2 %32 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: passo 2, imagem 3 %32
    • Remove the food tub by twisting it counter-clockwise with both hands and lifting it up.
  3. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: passo 3, imagem 1 %32
    • Remove the black plastic gasket from the top of the SmartFeeder by placing your fingers on the side of it and lifting up.
    • It should come off easily.
  4. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: passo 4, imagem 1 %32
    • Flip over the SmartFeeder by using both hands.
    • Partially open the outer case of the SmartFeeder by wedging an iFixit Opening Tool on each side.
  5. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: passo 5, imagem 1 %32 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: passo 5, imagem 2 %32
    • Turn the SmartFeeder on its side and with one hand on the base, carefully pull out the central section.
    • Place the bottom piece of the device right-side up.
  6. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: passo 6, imagem 1 %32 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: passo 6, imagem 2 %32
    • Remove one 10 mm screw by using the Phillips #1 screwdriver.
    • Remove the plastic retaining piece for the daughterboard by pulling it out with one hand.
  7. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: passo 7, imagem 1 %32 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: passo 7, imagem 2 %32 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: passo 7, imagem 3 %32
    • Pull the daughterboard out of the device and remove the three-prong connectors by using your hands.
    • Hold onto the sockets on the motherboard or you could accidentally pull off the entire assembly.
Conclusão
Ashley Kim
Membro desde: 10/08/18
187 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S13-G7, White Fall 2018 Membro de Cal Poly, Team S13-G7, White Fall 2018
CPSU-WHITE-F18S13G7
4 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 42
Ao todo: 523
