Ir para o conteúdo principal
Petmate 29027 Fountain Lid and Pump Replacement
O que você precisa
  1. Petmate 29027 Fountain Lid and Pump Replacement, Fountain Lid and Pump: passo 1, imagem 1 %32 Petmate 29027 Fountain Lid and Pump Replacement, Fountain Lid and Pump: passo 1, imagem 2 %32 Petmate 29027 Fountain Lid and Pump Replacement, Fountain Lid and Pump: passo 1, imagem 3 %32
    • Unplug the fountain from the electrical source and disconnect the inline plug.
    • Remove the lid.
    • Empty water from the fountain
    • Reach in the bowl and lift up the pump.
  2. Petmate 29027 Fountain Lid and Pump Replacement: passo 2, imagem 1 %32 Petmate 29027 Fountain Lid and Pump Replacement: passo 2, imagem 2 %32 Petmate 29027 Fountain Lid and Pump Replacement: passo 2, imagem 3 %32
    • Unclip the lid and intake plate using a fingernail.
  3. Petmate 29027 Fountain Lid and Pump Replacement: passo 3, imagem 1 %32 Petmate 29027 Fountain Lid and Pump Replacement: passo 3, imagem 2 %32
    • Pry out the impeller (4 white bladed propellers) which is held in place magnetically.
    • You can use a fingernail or small needle nose pliers to get under the plastic blade and lift it out.
  4. Petmate 29027 Fountain Lid and Pump Replacement: passo 4, imagem 1 %32 Petmate 29027 Fountain Lid and Pump Replacement: passo 4, imagem 2 %32 Petmate 29027 Fountain Lid and Pump Replacement: passo 4, imagem 3 %32
    • Clean the parts with warm soapy water and reassemble them.
    • Be sure to rinse thoroughly with fresh water.
    • Cleaning the motor with white vinegar (150ml) can increase disinfecting and hard water removal.
  5. Petmate 29027 Fountain Lid and Pump Replacement: passo 5, imagem 1 %32 Petmate 29027 Fountain Lid and Pump Replacement: passo 5, imagem 2 %32
    • Replace the pump into the original location.
    • Press down on the pump to engage the suction cups.
    • Place the fountain lid in the right place.
  6. Petmate 29027 Fountain Lid and Pump Replacement: passo 6, imagem 1 %32 Petmate 29027 Fountain Lid and Pump Replacement: passo 6, imagem 2 %32
    • Replug the fountain into electricity.
    • Add water as needed.
    • Never let the water level fall lower than the min fill line.
Linha de Chegada
Shidie Ren
Membro desde: 05/11/20
133 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 29
Duração total: 509
