Ir para o conteúdo principal
Performance Tool W50042 Trigger Switch Replacement
O que você precisa
  1. Performance Tool W50042 Trigger Switch Replacement, Trigger Switch: passo 1, imagem 1 %32
    • Remove the battery by pressing the yellow tabs on both sides, then pull the battery out.
  2. Performance Tool W50042 Trigger Switch Replacement: passo 2, imagem 1 %32 Performance Tool W50042 Trigger Switch Replacement: passo 2, imagem 2 %32 Performance Tool W50042 Trigger Switch Replacement: passo 2, imagem 3 %32
    • Remove the nine 1/2 inch Phillips head screws.
  3. Performance Tool W50042 Trigger Switch Replacement: passo 3, imagem 1 %32 Performance Tool W50042 Trigger Switch Replacement: passo 3, imagem 2 %32 Performance Tool W50042 Trigger Switch Replacement: passo 3, imagem 3 %32
    • Use a T-25 hex bit to remove four 1'1/2 hex head screws.
  4. Performance Tool W50042 Trigger Switch Replacement: passo 4, imagem 1 %32 Performance Tool W50042 Trigger Switch Replacement: passo 4, imagem 2 %32 Performance Tool W50042 Trigger Switch Replacement: passo 4, imagem 3 %32
    • Remove the shaft cover.
  5. Performance Tool W50042 Trigger Switch Replacement: passo 5, imagem 1 %32 Performance Tool W50042 Trigger Switch Replacement: passo 5, imagem 2 %32 Performance Tool W50042 Trigger Switch Replacement: passo 5, imagem 3 %32
    • Remove the case.
  6. Performance Tool W50042 Trigger Switch Replacement: passo 6, imagem 1 %32 Performance Tool W50042 Trigger Switch Replacement: passo 6, imagem 2 %32 Performance Tool W50042 Trigger Switch Replacement: passo 6, imagem 3 %32
    • Lift the trigger switch to remove the direction switch.
  7. Performance Tool W50042 Trigger Switch Replacement: passo 7, imagem 1 %32 Performance Tool W50042 Trigger Switch Replacement: passo 7, imagem 2 %32 Performance Tool W50042 Trigger Switch Replacement: passo 7, imagem 3 %32
    • Unscrew the red wire from the motor (Phillips head screw 1/4 inch).
  8. Performance Tool W50042 Trigger Switch Replacement: passo 8, imagem 1 %32 Performance Tool W50042 Trigger Switch Replacement: passo 8, imagem 2 %32 Performance Tool W50042 Trigger Switch Replacement: passo 8, imagem 3 %32
    • Pick up the motor and remove the black wire (Phillips head screw 1/4 inch).
Conclusão
Uma outra pessoa concluiu este guia.
David
Membro desde: 09/19/22
157 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 147
