Ir para o conteúdo principal
Pentax ZX-5n Flash Capacitor Unit
O que você precisa
  1. Pentax ZX-5n Flash Capacitor Unit, Remove back cover: passo 1, imagem 1 %32
    • Push down on the screw to depress the spring loaded hinge and release the door.
  2. Pentax ZX-5n Flash Capacitor Unit, Remove bottom cover: passo 2, imagem 1 %32
    • Remove six 5.3 mm #00 screws.
    • Remove one 3.4 mm #00 screw.
    • The short screw has a machine thread and screws into the plate underneath. The rest screw into the plastic body.
  3. Pentax ZX-5n Flash Capacitor Unit, Remove left front cover: passo 3, imagem 1 %32
    • Remove three 5.3 mm #00 screws (the bottom-most screw is not always present).
    • Remove one 7.3 mm #00 screw.
    • Remove the remote trigger cover.
  4. Pentax ZX-5n Flash Capacitor Unit, Remove front cover: passo 4, imagem 1 %32 Pentax ZX-5n Flash Capacitor Unit, Remove front cover: passo 4, imagem 2 %32
    • Remove two 5.3 mm #00 screw.
    • Gently lift up on the flash housing to help remove the cover if necessary.
  5. Pentax ZX-5n Flash Capacitor Unit, Remove right front cover: passo 5, imagem 1 %32
    • Remove two 3.9 mm #00 screws.
  6. Pentax ZX-5n Flash Capacitor Unit, Remove eye cup: passo 6, imagem 1 %32
    • Slide the eye cup up and off to access the screws underneath.
  7. Pentax ZX-5n Flash Capacitor Unit, Unscrew top cover: passo 7, imagem 1 %32 Pentax ZX-5n Flash Capacitor Unit, Unscrew top cover: passo 7, imagem 2 %32 Pentax ZX-5n Flash Capacitor Unit, Unscrew top cover: passo 7, imagem 3 %32
    • Remove two 5.3 mm #00 screws by the eyepiece.
    • Remove one 6.8 mm #00 screw in the battery compartment.
    • Remove one 7.0 mm #00 screw near the take up spool.
  8. Pentax ZX-5n Flash Capacitor Unit, Lift top cover: passo 8, imagem 1 %32
    • Lift the cover so it is just free of the body. It is still attached by several wires.
  9. Pentax ZX-5n Flash Capacitor Unit, Discharge flash capacitors: passo 9, imagem 1 %32
    • Use a 1kΩ-10kΩ resistor to discharge the capacitor. Place the resistor between the blue wire, exposed in the previous step, and ground.
    • The flash capacitors store energy at a very high voltage. Failing to discharge the capacitors properly could result in personal injury and/or damage to the camera.
  10. Pentax ZX-5n Flash Capacitor Unit, Release top cover: passo 10, imagem 1 %32
    • De-solder the green, blue, brown and black wires from the flash PCB.
  11. Pentax ZX-5n Flash Capacitor Unit, De-solder battery connections: passo 11, imagem 1 %32 Pentax ZX-5n Flash Capacitor Unit, De-solder battery connections: passo 11, imagem 2 %32 Pentax ZX-5n Flash Capacitor Unit, De-solder battery connections: passo 11, imagem 3 %32
    • Move the top cover to the side to access the battery connections. It is still connected by a flex cable.
    • De-solder the indicated joints. Use a solder sucker on the tabbed connections.
    • Pull the black wire from the battery flex to get more slack in the connection to the top cover.
    • Be careful not to overheat the flex circuit. Work in short durations. Allow for cool downs in between if necessary.
  12. Pentax ZX-5n Flash Capacitor Unit, Desolder flex cable: passo 12, imagem 1 %32
    • Desolder the flex cable connecting the top plate to the camera body.
    • The top cover can be completely removed at this point.
  13. Pentax ZX-5n Flash Capacitor Unit, De-solder flex posts: passo 13, imagem 1 %32
    • Use a solder sucker to de-solder the four posts from the flex circuit.
    • This is the most difficult part of the repair. Patience and persistence are required.
  14. Pentax ZX-5n Flash Capacitor Unit, De-solder flex connections: passo 14, imagem 1 %32
    • De-solder the marked connections.
  15. Pentax ZX-5n Flash Capacitor Unit, Unscrew flex circuit: passo 15, imagem 1 %32
    • Remove one 4.3 mm #00 screw.
  16. Pentax ZX-5n Flash Capacitor Unit, Lift the flex circuit: passo 16, imagem 1 %32 Pentax ZX-5n Flash Capacitor Unit, Lift the flex circuit: passo 16, imagem 2 %32
    • Gently pry up the plastic carrier under the flex circuit. It may catch slightly on the battery contact tab.
    • Pay close attention to the connections around the four through-hole posts as you lift the flex. Make sure that no solder is left over and that it pulls away freely.
    • This metal tab is lightly held in place with lacquer and can easily come loose. Keep an eye on it.
  17. Pentax ZX-5n Flash Capacitor Unit, Unscrew flash PCB: passo 17, imagem 1 %32
    • Remove one 3.3mm #00 screw.
    • Remove one 3.9 #00 screw.
    • De-solder the red wire.
    • Peel off the black tape. Leave it attached to the wires.
  18. Pentax ZX-5n Flash Capacitor Unit, Remove flash PCB and capacitors: passo 18, imagem 1 %32 Pentax ZX-5n Flash Capacitor Unit, Remove flash PCB and capacitors: passo 18, imagem 2 %32
    • Gently peel the flex circuit from the surface of the capacitor.
    • There may be additional adhesive underneath the larger capacitor.
    • Lift the two capacitors and the flash PCB out as a single unit.
    • The double sided tape used to secure the capacitors can be softened with isopropyl alcohol if necessary.
Conclusão
Sam Gustafson
Membro desde: 09/01/22
2.774 Reputação
Autoria de 13 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 108
