Ir para o conteúdo principal
Pentax Super Program Front Block Removal
O que você precisa
  1. Pentax Super Program Front Block Removal, Remove film advance lever: passo 1, imagem 1 %32 Pentax Super Program Front Block Removal, Remove film advance lever: passo 1, imagem 2 %32 Pentax Super Program Front Block Removal, Remove film advance lever: passo 1, imagem 3 %32
    • Remove the rubber decorative cap. It is attached with contact cement underneath. Isopropyl Alcohol may be used to soften the adhesive.
    • Unscrew the lock nut using a spanner wrench. The lock nut is reverse threaded.
    • Lift off the advance lever.
    • Remove the spring washer.
    • Remove one shim washer.
    Pergunte ao FixBot
    Comentar
  2. Pentax Super Program Front Block Removal, Remove mode dial: passo 2, imagem 1 %32 Pentax Super Program Front Block Removal, Remove mode dial: passo 2, imagem 2 %32
    • Set the mode dial to the 'L' position.
    • Use a spanner wrench to unscrew the dial lock nut.
    • Lift off the mode dial.
    Pergunte ao FixBot
    Comentar
  3. Pentax Super Program Front Block Removal, Remove exposure compensation dial: passo 3, imagem 1 %32 Pentax Super Program Front Block Removal, Remove exposure compensation dial: passo 3, imagem 2 %32 Pentax Super Program Front Block Removal, Remove exposure compensation dial: passo 3, imagem 3 %32
    • Place a rigid object in the fork.
    • Unscrew the rewind lever.
    • Use a spanner wrench to remove the lock nut.
    • Lift off the exposure compensation dial.
    Pergunte ao FixBot
    Comentar
  4. Pentax Super Program Front Block Removal, Remove top cover screws: passo 4, imagem 1 %32 Pentax Super Program Front Block Removal, Remove top cover screws: passo 4, imagem 2 %32 Pentax Super Program Front Block Removal, Remove top cover screws: passo 4, imagem 3 %32
    • Remove two screws on either side of the eye piece.
    • Remove two screws on either side of the lens mount.
    Pergunte ao FixBot
    Comentar
  5. Pentax Super Program Front Block Removal, Remove top cover: passo 5, imagem 1 %32 Pentax Super Program Front Block Removal, Remove top cover: passo 5, imagem 2 %32 Pentax Super Program Front Block Removal, Remove top cover: passo 5, imagem 3 %32
    • Remove one screw by the exposure compensation dial.
    • Use a spanner wrench to remove the lock nut under the advance lever.
    • Lift off the top cover slowly. It is still attached by one wire.
    • Unsolder one gray flash sync wire.
    Pergunte ao FixBot
    Comentar
  6. Pentax Super Program Front Block Removal, Remove bottom cover: passo 6, imagem 1 %32
    • Remove three M1.7 x 3 mm screws.
    • Remove bottom cover.
    Pergunte ao FixBot
    Comentar
  7. Pentax Super Program Front Block Removal, Remove front leatherette panels: passo 7, imagem 1 %32 Pentax Super Program Front Block Removal, Remove front leatherette panels: passo 7, imagem 2 %32 Pentax Super Program Front Block Removal, Remove front leatherette panels: passo 7, imagem 3 %32
    • Use a nickel or other large coin to remove the hand grip.
    • Drip isopropyl alcohol along the edge of the leatherette to soften the adhesive.
    • Use a dull scraper to lift one corner and pull off the panel.
    • Repeat on the rewind side of the camera.
    • Installation Notes: Use contact cement to reattach the leatherette after the camera has been fully reassembled and tested.
    Pergunte ao FixBot
    Comentar
  8. Pentax Super Program Front Block Removal, Detach flex PCB with adjustment pots: passo 8, imagem 1 %32 Pentax Super Program Front Block Removal, Detach flex PCB with adjustment pots: passo 8, imagem 2 %32
    • Remove one M1.7 x 4.5 mm screw.
    • Remove one slotted screw.
    • Use isopropyl alcohol to soften the adhesive under the flex PCB.
    • Gently lift the PCB until it is free from the camera body.
    Pergunte ao FixBot
    Comentar
  9. Pentax Super Program Front Block Removal, Unsolder motor drive connections: passo 9, imagem 1 %32 Pentax Super Program Front Block Removal, Unsolder motor drive connections: passo 9, imagem 2 %32
    • Unsolder red wire for positive battery.
    • Unsolder green wire.
    • Unsolder orange wire for motor drive shutter release.
    • Unsolder purple wire for wind completion switch.
    Pergunte ao FixBot
    Comentar
  10. Pentax Super Program Front Block Removal, Remove tripod mount: passo 10, imagem 1 %32 Pentax Super Program Front Block Removal, Remove tripod mount: passo 10, imagem 2 %32
    • Remove one M1.7 x 5 mm screw.
    • Remove one countersunk M1.7 x 5.5 mm screw.
    • Lift the contact terminal free from its seat.
    • Remove the tripod mount.
    Pergunte ao FixBot
    Comentar
  11. Pentax Super Program Front Block Removal, Detach ISO resistor assembly: passo 11, imagem 1 %32 Pentax Super Program Front Block Removal, Detach ISO resistor assembly: passo 11, imagem 2 %32
    • Remove one M1.7 x 4 mm screw.
    • Loosen one slotted screw (this will remain connected to the assembly).
    • Lift the ISO resistor assembly off the rewind post. It is still attached by a flex PCB.
    Pergunte ao FixBot
    Comentar
  12. Pentax Super Program Front Block Removal, Detach mode dial unit: passo 12, imagem 1 %32 Pentax Super Program Front Block Removal, Detach mode dial unit: passo 12, imagem 2 %32 Pentax Super Program Front Block Removal, Detach mode dial unit: passo 12, imagem 3 %32
    • Remove one M1.7 x 2.5 mm screw. It is only accessible when the mode dial is in the 'L' position.
    • Lift the LCD out of the way. It is still attached by a flex PCB.
    • Remove one slotted post.
    Pergunte ao FixBot
    Comentar
  13. Pentax Super Program Front Block Removal, Unsolder flash sync wires: passo 13, imagem 1 %32
    • Unsolder two gray wires.
    Pergunte ao FixBot
    Comentar
  14. Pentax Super Program Front Block Removal, Unsolder shutter wires: passo 14, imagem 1 %32 Pentax Super Program Front Block Removal, Unsolder shutter wires: passo 14, imagem 2 %32
    • Unsolder white wire.
    • Unsolder brown wire.
    • Unsolder red wire.
    Pergunte ao FixBot
    Comentar
  15. Pentax Super Program Front Block Removal, Unscrew mirror box: passo 15, imagem 1 %32 Pentax Super Program Front Block Removal, Unscrew mirror box: passo 15, imagem 2 %32
    • Remove two M1.7 x 2.5 mm screws.
    • Remove one M1.7 x 3.5 mm screw under the bottom plate.
    • Some versions of the camera may have an additional screw under the tripod mount that needs to be removed.
    Pergunte ao FixBot
    Comentar
  16. Pentax Super Program Front Block Removal, Unscrew front board: passo 16, imagem 1 %32 Pentax Super Program Front Block Removal, Unscrew front board: passo 16, imagem 2 %32
    • Wind the advance lever to put the shutter and mirror box in the charged state.
    • Remove four M1.9 x 5 mm screws.
    Pergunte ao FixBot
    Comentar
  17. Pentax Super Program Front Block Removal, Remove mirror box and front board: passo 17, imagem 1 %32
    • Make sure the mode dial unit and ISO selector unit are free from their mounting points.
    • Wiggle the mirror box and front board free.
    • Watch for wire snags as you pull it free.
    • Check for loose shim washers on the front board and note their position.
    Pergunte ao FixBot
    Comentar
  18. Pentax Super Program Front Block Removal, Installation Notes: Front Block: passo 18, imagem 1 %32
    • Shutter should be in the charged state.
    • Mirror box should be in released state.
    • Pay close attention to wire routing during install.
    • To test the actuation of the mirror and shutter, wind the camera, then insert a tool into this slot and push the release lever to the left.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Sam Gustafson
Membro desde: 09/01/22
11.000 Reputação
Autoria de 75 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 39
Ao todo: 322
