Ir para o conteúdo principal
Pentax Spotmatic Top Cover Removal
O que você precisa
  1. Pentax Spotmatic Top Cover Removal, Remove frame counter: passo 1, imagem 1 %32 Pentax Spotmatic Top Cover Removal, Remove frame counter: passo 1, imagem 2 %32 Pentax Spotmatic Top Cover Removal, Remove frame counter: passo 1, imagem 3 %32
    • Loosen three grub screws. Do not remove them from the frame counter cover.
    • Lift off frame counter cover.
    • Remove one 2.5 mm flat head screw. It is reverse or left-hand threaded.
    • Remove the frame counter dial.
    • Remove the retaining nut using a spanner wrench. A pair of fine tipped nippers can also work.
    • On some Spotmatics, this nut may be reverse threaded. Work carefully.
    • Remove the dial seat.
  2. Pentax Spotmatic Top Cover Removal, Remove advance lever: passo 2, imagem 1 %32 Pentax Spotmatic Top Cover Removal, Remove advance lever: passo 2, imagem 2 %32 Pentax Spotmatic Top Cover Removal, Remove advance lever: passo 2, imagem 3 %32
    • Remove three 2.3 mm flat head screws.
    • Use a pick to rotate the retaining washer until the lobed sections are free.
    • Lift off the advance lever.
    • Remove the plastic shim washer.
  3. Pentax Spotmatic Top Cover Removal, Remove shutter speed dial: passo 3, imagem 1 %32 Pentax Spotmatic Top Cover Removal, Remove shutter speed dial: passo 3, imagem 2 %32 Pentax Spotmatic Top Cover Removal, Remove shutter speed dial: passo 3, imagem 3 %32
    • Remove one 2.8 mm pin head screw.
    • The dial assembly is spring loaded. Keep two fingers on top of the dial as you are loosening the screw to prevent it from popping off.
    • Remove the shutter speed dial.
    • Remove the ISO dial.
    • Remove the internal spring.
    • Remove the dial housing.
  4. Pentax Spotmatic Top Cover Removal, Installation Notes: Shutter Speed Dial: passo 4, imagem 1 %32 Pentax Spotmatic Top Cover Removal, Installation Notes: Shutter Speed Dial: passo 4, imagem 2 %32
    • The hole in the dial housing needs to go over the tab on the speed resistor.
    • The tab on the ISO dial needs to mate with the hole in the dial housing.
    • It can be difficult to line everything up while compressing the spring and installing the center screw. Be patient.
  5. Pentax Spotmatic Top Cover Removal, Remove film winder assembly: passo 5, imagem 1 %32 Pentax Spotmatic Top Cover Removal, Remove film winder assembly: passo 5, imagem 2 %32 Pentax Spotmatic Top Cover Removal, Remove film winder assembly: passo 5, imagem 3 %32
    • Place a thin, sturdy tool in the spindle fork.
    • Unscrew the rewind knob.
    • Use a spanner wrench to unscrew the retaining nut.
    • Remove the film reminder
    • Remove the spring washer.
    • Remove the friction plate.
  6. Pentax Spotmatic Top Cover Removal, Remove top cover: passo 6, imagem 1 %32 Pentax Spotmatic Top Cover Removal, Remove top cover: passo 6, imagem 2 %32
    • Remove one 3.0 mm flat head screw.
    • Remove top cover.
Conclusão
Sam Gustafson
Membro desde: 09/01/22
7.682 Reputação
Autoria de 42 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 16
Últimos 30 dias: 74
Duração total: 259
