Ir para o conteúdo principal
Pentax PZ-10 Button Replacement
O que você precisa
  1. Pentax PZ-10 Button Replacement, Top Cover: passo 1, imagem 1 %32
    • The top cover is one piece encasing the top of the device except the shutter release button and flash.
  2. Pentax PZ-10 Button Replacement, Removing Upper Right Housing Screw: passo 2, imagem 1 %32 Pentax PZ-10 Button Replacement, Removing Upper Right Housing Screw: passo 2, imagem 2 %32
    • With the camera lens face down, locate the screw under the overhanging piece of the top casing on the right side of the back panel.
    • Using the J0 screwdriver, remove the 6.3 mm screw.
  3. Pentax PZ-10 Button Replacement, Removing Screw in Battery Compartment: passo 3, imagem 1 %32 Pentax PZ-10 Button Replacement, Removing Screw in Battery Compartment: passo 3, imagem 2 %32
    • Locate the next screw by holding the camera upside down with the battery compartment empty and face up.
    • Remove the 6.3 mm screw using a J0 screwdriver.
  4. Pentax PZ-10 Button Replacement, Removing Screw Under Flash Bulb: passo 4, imagem 1 %32 Pentax PZ-10 Button Replacement, Removing Screw Under Flash Bulb: passo 4, imagem 2 %32
    • The next screw is found in the overhanging piece just above the lens.
    • With the top of the camera facing down, remove the 3.4 mm screw with a J0 screwdriver.
  5. Pentax PZ-10 Button Replacement, Pulling Off the Top Cover: passo 5, imagem 1 %32 Pentax PZ-10 Button Replacement, Pulling Off the Top Cover: passo 5, imagem 2 %32
    • Gently pull off the top cover with your hands by pulling on the tab on the left of the camera.
  6. Pentax PZ-10 Button Replacement, Locate Rubber Tabs: passo 6, imagem 1 %32 Pentax PZ-10 Button Replacement, Locate Rubber Tabs: passo 6, imagem 2 %32
    • Gently remove the beige rubber tabs from under the casing by pulling each down using tweezers.
  7. Pentax PZ-10 Button Replacement: passo 7, imagem 1 %32
    • Remove the 3 buttons by pushing them from under the casing out through the top.
    • Each button is slotted differently, so pay attention to the orientation of each piece.
  8. Pentax PZ-10 Button Replacement, Buttons: passo 8, imagem 1 %32
    • The buttons are now free to be replaced or cleaned.
Conclusão
Jonathan Diaz
Membro desde: 04/20/15
213 Reputação
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 497
