Ir para o conteúdo principal
Pentax Optio WP Battery and SD Card Replacement
  1. Pentax Optio WP Battery and SD Card Replacement, Battery and SD Card: passo 1, imagem 1 %32
    • The camera used to make this manual does not contain a battery or SD card
    • Orient the camera so you are looking at the bottom and the battery compartment is on the right hand side.
  2. Pentax Optio WP Battery and SD Card Replacement: passo 2, imagem 1 %32 Pentax Optio WP Battery and SD Card Replacement: passo 2, imagem 2 %32
    • Unlock the battery compartment by sliding the lock switch to the unlock position (away from the arrow).
    • Firmly push the battery cover to the right and swing open.
    • The battery will be located in the larger bottom slot. Slide the plastic orange tab to remove the battery.
    • The SD card will be located in the smaller, top slot. Push the SD card directly in to hear a small clicking sound. Then pull out the SD card.
Conclusão
Olivia Nixon
Membro desde: 01/16/11
429 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 1-13, Amido Winter 2011 Membro de Cal Poly, Team 1-13, Amido Winter 2011
CPSU-AMIDO-W11S1G13
Membros da 5
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 29
Duração total: 3,878
