Ir para o conteúdo principal
Pentax Optio WG-3 GPS Motherboard Replacement
O que você precisa
  1. Pentax Optio WG-3 GPS Motherboard Replacement, Motherboard: passo 1, imagem 1 %32
    • Turn over the camera so the screen is facing up.
    • Remove the four 5 mm Phillips #000 screws that secure the outer cover.
  2. Pentax Optio WG-3 GPS Motherboard Replacement: passo 2, imagem 1 %32
    • Flip over the camera so the bottom is facing up.
    • Use the Phillips PH0005 again to remove one more 5mm screw.
    • Remove the cover.
  3. Pentax Optio WG-3 GPS Motherboard Replacement: passo 3, imagem 1 %32
    • Remove the eight 5 mm Phillips #000 screws holding the circuitry together.
  4. Pentax Optio WG-3 GPS Motherboard Replacement: passo 4, imagem 1 %32
    • Carefully remove the circuitry.
  5. Pentax Optio WG-3 GPS Motherboard Replacement: passo 5, imagem 1 %32
    • There is a large silver sticker on top of the motherboard, gently remove it off of the motherboard.
  6. Pentax Optio WG-3 GPS Motherboard Replacement: passo 6, imagem 1 %32
    • Gently use the spudger set to lift open the clamps that are holding the orange ribbons down.
    • Pull out the ribbons and remove the motherboard from the body of the camera.
  7. Pentax Optio WG-3 GPS Motherboard Replacement: passo 7, imagem 1 %32
    • Remove the battery on the back of the motherboard.
  8. Pentax Optio WG-3 GPS Motherboard Replacement: passo 8, imagem 1 %32
    • Unscrew and remove one 2 mm Phillips #00 screw to remove the flash component on the top of the circuitry.
  9. Pentax Optio WG-3 GPS Motherboard Replacement: passo 9, imagem 1 %32
    • Remove three 5 mm Phillips #000 screws from the left side of the motherboard.
  10. Pentax Optio WG-3 GPS Motherboard Replacement: passo 10, imagem 1 %32
    • Remove two ribbon cables from the small circuit.
    • Remove the ribbon cable that holds the sensor to the motherboard.
  11. Pentax Optio WG-3 GPS Motherboard Replacement: passo 11, imagem 1 %32
    • The sensor is ready to be pulled out, carefully remove the sensor.
  12. Pentax Optio WG-3 GPS Motherboard Replacement: passo 12, imagem 1 %32
    • Unscrew and remove three 5 mm screws from the front panel of the battery compartment.
  13. Pentax Optio WG-3 GPS Motherboard Replacement: passo 13, imagem 1 %32
    • Pull the black panel away from the front panel.
  14. Pentax Optio WG-3 GPS Motherboard Replacement: passo 14, imagem 1 %32
    • At the top of the circuit board there are three soldered dots that need to be unsoldered to remove the back of the battery component from the motherboard.
    • The motherboard can now be pulled and replaced.
Conclusão
Garrett Rose
Membro desde: 03/31/22
373 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 3-1, Harley Spring 2022 Membro de IUPUI, Team 3-1, Harley Spring 2022
IUPUI-HARLEY-S22S3G1
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 11
Duração total: 193
