Ir para o conteúdo principal
Pentax Optio WG-3 GPS Lens Assembly Replacement
O que você precisa
  1. Pentax Optio WG-3 GPS Lens Assembly  Replacement, Lens Assembly: passo 1, imagem 1 %32
    • Turn over the camera so the screen is facing up.
    • Remove the four 5 mm Phillips #000 screws that secure the outer cover.
  2. Pentax Optio WG-3 GPS Lens Assembly  Replacement: passo 2, imagem 1 %32
    • Flip over the camera so the bottom is facing up.
    • Remove the single Phillips #000 screw.
    • Remove the cover.
  3. Pentax Optio WG-3 GPS Lens Assembly  Replacement: passo 3, imagem 1 %32
    • Remove the eight 5 mm Phillips #000 screws holding the circuitry together.
  4. Pentax Optio WG-3 GPS Lens Assembly  Replacement: passo 4, imagem 1 %32
    • Carefully remove the circuitry.
  5. Pentax Optio WG-3 GPS Lens Assembly  Replacement: passo 5, imagem 1 %32
    • Flip the circuitry so that the lens is facing up and the flash component is on your right.
    • Identify the orange ribbon tape surrounding the lens.
  6. Pentax Optio WG-3 GPS Lens Assembly  Replacement: passo 6, imagem 1 %32
    • There are three 5 mm Phillips #000 screws to be removed on the right side of the lens.
  7. Pentax Optio WG-3 GPS Lens Assembly  Replacement: passo 7, imagem 1 %32
    • Gently slide the lens piece to the right, remove the tape and take it out.
Conclusão
Garrett Rose
Membro desde: 03/31/22
373 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 3-1, Harley Spring 2022 Membro de IUPUI, Team 3-1, Harley Spring 2022
IUPUI-HARLEY-S22S3G1
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 155
