Ir para o conteúdo principal
Pentax Optio WG-3 GPS Flash Replacement
O que você precisa
  1. Pentax Optio WG-3 GPS Flash Replacement, Flash: passo 1, imagem 1 %32
    • Turn over the camera so the screen is facing up.
    • Remove the four 5 mm Phillips #000 screws that secure the outer cover.
  2. Pentax Optio WG-3 GPS Flash Replacement: passo 2, imagem 1 %32
    • Flip over the camera so the bottom is facing up.
    • Remove the single Phillips #000 screw.
    • Remove the cover.
  3. Pentax Optio WG-3 GPS Flash Replacement: passo 3, imagem 1 %32
    • Remove the eight 5 mm Phillips #000 screws holding the circuitry together.
  4. Pentax Optio WG-3 GPS Flash Replacement: passo 4, imagem 1 %32
    • Carefully remove the circuitry.
  5. Pentax Optio WG-3 GPS Flash Replacement: passo 5, imagem 1 %32
    • Upon removing the flash, there is a 2 mm screw that needs to be removed.
  6. Pentax Optio WG-3 GPS Flash Replacement: passo 6, imagem 1 %32
    • Remove the ribbon cable that attaches the flash from the circuitry.
  7. Pentax Optio WG-3 GPS Flash Replacement: passo 7, imagem 1 %32
    • Remove the three 2 mm Phillips #000 screws from the left side of the circuitry.
    • These screws attach the circuit board to the shell of the camera.
    • Remove the circuitry from the front side of the camera
  8. Pentax Optio WG-3 GPS Flash Replacement: passo 8, imagem 1 %32
    • Find and remove the camera battery.
  9. Pentax Optio WG-3 GPS Flash Replacement: passo 9, imagem 1 %32
    • Remove the final two 2 mm Phillips #000 screws from the front side of the circuitry.
  10. Pentax Optio WG-3 GPS Flash Replacement: passo 10, imagem 1 %32
    • Pull the black front panel away from the circuitry.
    • The black panel is attached to the flash and is now ready to be removed and replaced.
    • The sensor is enclosed in the white case.
Conclusão
Cassandra Stec
Membro desde: 03/14/22
181 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team 3-1, Harley Spring 2022 Membro de IUPUI, Team 3-1, Harley Spring 2022
IUPUI-HARLEY-S22S3G1
3 Membros
Autoria de 3 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 13
Ao todo: 286
