Ir para o conteúdo principal
Penn-Plax Cascade 20 Power Filter Impeller Replacement
O que você precisa
  1. Penn-Plax Cascade 20 Power Filter Impeller Replacement, Impeller: passo 1, imagem 1 %32
    • Start by placing filter system on your workstation of choice.
  2. Penn-Plax Cascade 20 Power Filter Impeller Replacement: passo 2, imagem 1 %32 Penn-Plax Cascade 20 Power Filter Impeller Replacement: passo 2, imagem 2 %32 Penn-Plax Cascade 20 Power Filter Impeller Replacement: passo 2, imagem 3 %32
    • Remove all detachable pieces from the filter. This includes the lid, pipe, and filter media.
  3. Penn-Plax Cascade 20 Power Filter Impeller Replacement: passo 3, imagem 1 %32 Penn-Plax Cascade 20 Power Filter Impeller Replacement: passo 3, imagem 2 %32 Penn-Plax Cascade 20 Power Filter Impeller Replacement: passo 3, imagem 3 %32
    • Take your filter and place it upside down.
    • Place your hand on the motor. Grab it firmly and turn it clockwise for a quarter turn. When the turn is complete, it should look like the second picture.
    • Pull the motor up and out from the filter chassis.
    • The motor should be able to be pulled off with ease.
  4. Penn-Plax Cascade 20 Power Filter Impeller Replacement: passo 4, imagem 1 %32 Penn-Plax Cascade 20 Power Filter Impeller Replacement: passo 4, imagem 2 %32 Penn-Plax Cascade 20 Power Filter Impeller Replacement: passo 4, imagem 3 %32
    • Take your index finger and thumb and firmly grip one of the impeller blades.
    • Pull the impeller up and out of the motor shaft.
    • You should feel mild resistance because the impeller is secured via magnet.
  5. Penn-Plax Cascade 20 Power Filter Impeller Replacement: passo 5, imagem 1 %32 Penn-Plax Cascade 20 Power Filter Impeller Replacement: passo 5, imagem 2 %32 Penn-Plax Cascade 20 Power Filter Impeller Replacement: passo 5, imagem 3 %32
    • To install a new impeller, grab it by the fins and place it back into the motor shaft hole.
    • Push the new impeller in and make sure it is connected to the magnetic seal. This can be checked by flipping the motor upside down and seeing if the impeller falls out.
Conclusão
Your Penn-Plax Cascade 20 Power Filter should be up and running again!
Uma outra pessoa concluiu este guia.
Danny Vo
Membro desde: 03/06/22
145 Reputação
Autoria de 1 guia
Equipe
UM-KIM-S22SM50G2 Membro de UM-KIM-S22SM50G2
Community
Membros da 3
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 15
Duração total: 544
