Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
O que você precisa
Mit Opening Picks wird an einer Vertiefung unten links (etwa sieben Uhr) beginnen das Display gegen den Uhrzeigersinn abgehebelt. Das Diplay ist an der linken Seite mit einer Felxband verbunden und muss von der Platine getrennt werden.
Nun alles wieder in umgekehrter Reihenfolge zusammensetzten. Den Dichtungkleber vor dem Aufsetzten des Diplays entfernen und mit neuem https://eustore.ifixit.com/Werkzeuge/Ver... rundherum bekleben.
Dann das Diplay einsetzten und festdrücken.
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
2 comentários
thanks , I managed to fix my pebble time steel with this guide. it may not be waterproof but at least my buttons no longer stick…
I think the reason it failed was because some water already got inside… could get my pebble starting anymore
Works great! Thanks for the guide :D
I would've liked to add an additional step, but it doesn't appear that I can - one other thing that I've found can cause buttons to stick is in the inside of the casing, on each button there's a little circlip that sits in a detent on the pokey bit - if this comes out of its detent, then the button can become quite hard to press and hard to work with. Unfortunately I can't post pictures here, but there's a picture in this Imgur thread of what I'm talking about: https://imgur.com/gallery/V4SUvbz
