Introdução
The watch is opened and i think it won't be waterrestant any more after this.
O que você precisa
With opening picks we start to open the watch by lifting up the display bottom from left (about seven o'clock) in counterclockwise direction. In the left side there is a flexband that has to be disconnected.
Repeat the steps in reverse order to reassemble your device.
Um agradecimento especial a esses tradutores:
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
2 comentários
thanks , I managed to fix my pebble time steel with this guide. it may not be waterproof but at least my buttons no longer stick…
I think the reason it failed was because some water already got inside… could get my pebble starting anymore
Works great! Thanks for the guide :D
I would've liked to add an additional step, but it doesn't appear that I can - one other thing that I've found can cause buttons to stick is in the inside of the casing, on each button there's a little circlip that sits in a detent on the pokey bit - if this comes out of its detent, then the button can become quite hard to press and hard to work with. Unfortunately I can't post pictures here, but there's a picture in this Imgur thread of what I'm talking about: https://imgur.com/gallery/V4SUvbz
